SMath Studio Forum
Download SMath Studio
Stable: SMath Studio 0.99.7610 (01 November 2020)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,472   Was thanked: 1735 time(s) in 587 post(s)
New Stable SMath Studio 0.99.7610 is available!Tiny, powerful, free mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. Changes introduced in current buildImprovements- Program start up speed significantly improved;
- The following units added: klx, μT, mT, klm, μWb, mWb;
- Toolbox icons vectorized;
- Cloud: SVG icons for toolboxes in supported now;
- Better support implemented for OS dark mode.
Corrections- Support for high dpi systems restored;
- importData() function improved to support special chars in path;
- Ohm unit representation fixed for Russian localization;
- Android: Scaled images supported now;
- Android: Filling in a text is fixed for some onscreen keyboards;
- Working with images on Linux fixed (save/open, copy/paste);
- Color of the underlined text corrected;
- Text which contains link shown underlined again;
- Toolbox icons made visible on Mono;
- Export to PDF fixed on Linux;
- Cloud: All units/function selection fixed into insert dialog;
- Splash screen layout fixed on Linux.
Miscellaneous- Worksheets rendering quality normalized between Mono and .Net frameworks;
- Refactoring.
DownloadSystem requirements - Desktop (Windows):
- Desktop (Linux):
Interface languages (37 languages) - [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
Tutorial SMath Studio tutorial by Bernard Liengme. SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons (  ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
on 01/11/2020(UTC), on 01/11/2020(UTC), on 01/11/2020(UTC), on 03/11/2020(UTC), on 06/11/2020(UTC)
Was thanked: 9 time(s) in 8 post(s)
Can't work with EFI plugin.
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,101   Was thanked: 972 time(s) in 557 post(s)
Last EFI build is experimental. I will remove it. I asked Andrey to check one bug. |
I see that the following plug-ins handles 0 (zero) functions now: - efi - dislin - matlab c++ - octave c++ - probe properties
Regarding efi: I'm looking at the issue right now.
Originally Posted by: Andrey Ivashov  I see that the following plug-ins handles 0 (zero) functions now: - efi - dislin - matlab c++ - octave c++ - probe properties
Regarding efi: I'm looking at the issue right now. Prode Properties: You need to install Prode first. The plugin is just a wrapper. Matlab C++ Math Library: For x32 only, but I have one idea how to make x64 support available. Mathcad EFI: Also only for x32, but it is possible to make x64 support. DISLIN: The library itself has recently been updated. I will try to update the plugin by changing the way the functions are loaded. Octave C++ Math Library: Also only 32-bit Octave library exists. |
Joined: 23/07/2013(UTC) Posts: 202  Was thanked: 59 time(s) in 42 post(s)
Also maple don't work under linux with mono.
SMath Studio Forum
