Joined: 04/07/2015(UTC) Posts: 6,795  Was thanked: 974 time(s) in 802 post(s)
Originally Posted by: Alex.M  Jean, on a side note, what is your comment on a quality of DISLIN generated plots? There are already so many 3D plots, many are freeware. Scilab, DISLIN ... Surfer 8 [dedicated Contour plot, not freeware]. I see DISLIN via a menu driven and equation editor, Mathcad style. The first thing is a the same CreateMesh than Mathcad. Let say the two planes X, Y and the level Z plane and in parametric style. That sets the complete 3 D system, meshed at will and supporting the entire user rotation from command line as well as cylindrical/ spherical plots and export the corresponding matrices. Contour is something else of much different nature. Contour plots ends being an XY plot. I have a Mathcad contour program [done by Collab]. Just scared to attempt Coding in Smath. Some of you gurus, I can make an image of the program for your bed time reading. There remains the question about freeware: how far can somebody reverse Engineer and redistribute ? Cheers Alex, Jean
... that's what I meant about a comprehensive "DISLIN start". Contour is for exporting specific contour data. The feed is a matrix, either well populated or splined and you get what you want. Collapse the function, plug the matrix from source or from function ... ready for the contour(s), just few clicks. I lost patience trying to imitate Mathcad "on error". So, attempting the program is not tempting. The program images included in the *.sm work sheet. Jean  Contour Electron.sm (240kb) downloaded 44 time(s).
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,614   Was thanked: 1977 time(s) in 665 post(s)
Hello.
Currently I'm working to improve SMath Studio start up time. Have good results (made it up to 4x faster), but I've found that DISLIN plug-in requires from 4 to 14 seconds (different environment) to response on call to GetTermsHandled. Which is the most significant part of SMath Studio start up time.
Is it possible to improve the logic here?
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,469   Was thanked: 1256 time(s) in 731 post(s)
I'll see what I can do or will change the way I use it. |
on 27/10/2020(UTC), on 27/10/2020(UTC), on 27/10/2020(UTC)
Updated. Refactored. Startup time has been reduced.  Edited by user 04 November 2020 22:27:11(UTC)
... native SS 6179 ... sorry but I have no interest *.svg Stand alone user command line is more my cup of tea.
 Updated. Changes: - updated to DISLIN 11.3.3 (799 functions); - refactored. Quote:Grant of Free Usage
You are allowed to use DISLIN for free. Either as a private person or in a commercial or non-commercial environment. There are no limitations.
 DISLIN. Example 1.sm (96kb) downloaded 119 time(s). DISLIN. Example 1.pdf (288kb) downloaded 126 time(s).Edited by user 01 June 2022 20:53:00(UTC)
on 06/11/2020(UTC), on 06/11/2020(UTC)
 Plugin updated. Changes: - updated to DISLIN 11.5 (799 functions); - string encoding bug fixed; - refactored.  Edited by user 01 June 2022 20:34:46(UTC)
 4 users thanked uni for this useful post.
on 01/06/2022(UTC), on 02/06/2022(UTC), on 02/06/2022(UTC), on 02/06/2022(UTC)
