5 Pages«<2345>
Offline Andreas Hildebrandt
#61 Posted : 22 April 2020 13:45:50(UTC)
Andreas Hildebrandt
Originally Posted by: uni Go to Quoted Post
Updated. Experimental build. Be careful with this. You need to update X-Y Plot first.
P.S. "Name" property is not saved. This will be more difficult to fix, as component uses a binary format for storing settings.
Thank's a lot!!! This is exactly what I was looking for.
You are genius.
#62 Posted : 22 April 2020 19:33:41(UTC)
1. click/click to open your spec stuff
2. click/click to open Zed all spec
Same for less vs same for more !
Stupid Zed ... missing the most delicious line "spline".
#63 Posted : 22 April 2020 20:36:48(UTC)
What is it Zed does not understand ?
#64 Posted : 23 April 2020 02:04:39(UTC)
No shame to publish ... few seconds = done.
Offline hanskl
#65 Posted : 26 October 2020 11:13:16(UTC)
hanskl
Norway
Was thanked: 7 time(s) in 5 post(s)
Is it possible to make Zedgraph plot functions with built in conditional programming, ie. if ()?
Also, is it possible to alter the numbers along the axis when log scale is chosen such that the numbers is not written in 10^x?
Offline uni
#66 Posted : 26 October 2020 13:18:43(UTC)
uni
I think it is possible if I change the plugin. I'll try do that.
The external design is not yet fully tested, but you can do this.
problem_log (uni).sm (692kb) downloaded 49 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 26/10/2020(UTC)
Offline hanskl
#67 Posted : 26 October 2020 17:04:37(UTC)
hanskl
Norway
Thank you. Do you think it's possible to make Zedgraph plot my function when the function uses if() instead of cases() to break the for loop?
(in the sheet cases() is used to break the loop, but cases() doesn't actually work.. no iterations are made, the loop is broken after the first run).
Offline uni
#68 Posted : 26 October 2020 18:37:57(UTC)
uni
Updated. Try now.
Russia ☭ forever
Offline hanskl
#69 Posted : 26 October 2020 19:29:50(UTC)
hanskl
Norway
Updated. Try now.
Do I have to delete Zedgraph and make a fresh install?
I tried making a new sheet with a new Zedhgraph - still "x - not defined" when if() is used in the function.
Offline uni
#70 Posted : 26 October 2020 19:34:33(UTC)
uni
No, you must update it using the main menu: Tools\Plugins (Local Storage) - ZedGgraph Region (Update).
Russia ☭ forever
on 26/10/2020(UTC)
Offline hanskl
#71 Posted : 26 October 2020 20:45:26(UTC)
hanskl
Norway
I went to the plugin manager to check, but I didnt check the online gallery, thus there was no update for me.
I updated from online gallery now and it works! Both the option for "IsUseTenPower" and plotting a function with if() conditional.
I am a very happy camper now. Thank you very much!
#72 Posted : 26 October 2020 20:55:16(UTC)
Maybe not needed at all. My ZedGraph ancestor plots data OK.
Some patient Collab might be willing. I hate that beast, it punishes me !
As it plots data, for multiple plot will have to be dressed in matrix,
then collect each plot piece.
Project Hanski Soil Drainage Ng User.sm (313kb) downloaded 20 time(s).
Offline hanskl
#73 Posted : 27 October 2020 00:04:54(UTC)
hanskl
Norway
another question - is it possible to have a "dynamic" number format? such that 100 is written as 100 and not 100.0, while 0.1 is written as 0.1?
#74 Posted : 27 October 2020 00:14:09(UTC)
... demo 3 plots added on Zedgraph.
I don't speak enough Aliens to finish a presentable plot.
subdivide X axis, make tick labels visible rather than microscopic...
Project Hanski Soil Drainage Ng User.sm (587kb) downloaded 26 time(s).
Offline uni
#75 Posted : 27 October 2020 05:25:27(UTC)
uni
Try Scale.Format = g2 or g3
Russia ☭ forever
Offline hanskl
#76 Posted : 27 October 2020 10:10:26(UTC)
hanskl
Norway
Worked like a charm! One last request (I think) - is it possible to have the minor and major step linear while using a log scale?
Now my major steps are 0,1 1 10 and 100. Is it possible to divide each range in 10?
#77 Posted : 28 October 2020 02:54:09(UTC)
... latest attempt demo.
Project Hanski Soil Drainage Ng ZedGraph.sm (396kb) downloaded 28 time(s).
#78 Posted : 28 October 2020 03:20:06(UTC)
The major'y' grids are linear wrt the pixels in height,
but not the labels [naturally]. Minor grids are confusing.
Thus the idea of tracking and display the XY coordinates.
Offline uni
#79 Posted : 21 November 2020 13:59:28(UTC)
uni
Updated.
Changes:
- SS-4652 partially fixed.
Edited by user 21 November 2020 14:10:28(UTC)  | Reason: Not specified
Russia ☭ forever
on 21/11/2020(UTC),  on 21/11/2020(UTC)
Offline mkraska
#80 Posted : 10 August 2023 12:24:35(UTC)
mkraska
- insert a zedgraph region
- set YAxis> Type to log.
This freezes the UI, only option is to kill SMath in the program manager. Version 8348.
I understand that log axes must have positive limits. Just a hint on a trap for uncautious users.
on 23/09/2023(UTC)
5 Pages«<2345>
