3 Pages<123>
Offline overlord
#21 Posted : 14 October 2020 23:00:19(UTC)
Turkey
Was thanked: 485 time(s) in 320 post(s)
Originally Posted by: Davide Carpi Go to Quoted Post
the PNG file has 2 colors (black and transparent black), however PNG format has alpha channel while GIF has just transparency. Transparency on black color might be the problem in mono?
On old button images alpha (transparent) color is white.
All colors are black on new images, even alpha channels.
If you make alpha channel as overlay all image is black.
Davide's suggestion could work.
Coloring alpha as white or another color can fix the problem.
Regards.
Offline overlord
#22 Posted : 14 October 2020 23:13:04(UTC)
Turkey
Originally Posted by: ElSid Go to Quoted Post
Because it's Windows Crazy ! There may be something internal to Windows coded to check for visibility.
Davide beat me to my first inclination, the transparency feature available in PNG format. However, I run the portable version on Windows and copied the files to Linux, so it's the same folders/folder structure
Question, on Linux, am I suppose to double click on "SMathStudio_Desktop.exe" or "smathstudio_desktop_mono" {no extension}. My version of "smathstudio_desktop_mono" is dated 05/30/2013. The following is what's in that file
Actually it should not be shown on Windows too, as Davide looked into it all colors are black on buttons.
If alpha color and image color is all black, all image should be transparent. And button image shouldn't be seen.
Sometimes Windows is driving me crazy indeed.
For more convenient and faster experience, .Net windows executables should be run with Mono if Mono supports the targeted executable.
Wine can be used as compatibility layer by clicking "SMathStudio_Desktop.exe", if you installed Wine of course. But it will be slower.
Offline ElSid
#23 Posted : 15 October 2020 16:03:16(UTC)
ElSid
New poster, same Linux as I, full toolbar https://en.smath.com/for...interface.aspx#post66250
Offline Andrey Ivashov
#24 Posted : 15 October 2020 16:36:29(UTC)
Was thanked: 1977 time(s) in 665 post(s)
Please try this build: http://smath.com/file/nbUXn - created for testing only. It has SVG based icons on Boolean toolbox. Windows & Linux. They are not that sharp as before, but at least we can check if they are visible and readable. These icons uses system color for text now (instead of black in PNG images).
If it will be OK all the buttons can be recreated using this technic.
Offline overlord
#25 Posted : 15 October 2020 16:58:59(UTC)
Turkey
This is how it is on my setup.
Same as previous builds.
#26 Posted : 15 October 2020 17:15:34(UTC)
Hmm, then this is not because of incorrect image...
#27 Posted : 15 October 2020 22:22:37(UTC)
Was thanked: 1322 time(s) in 872 post(s)
If you move the toolboxes as closest as possible to the top/left corner of the screen(s) (with small or null canvas width) something appears?
Edited by user 15 October 2020 22:27:03(UTC)  | Reason: Not specified
#28 Posted : 15 October 2020 23:59:43(UTC)
One more attempt: http://smath.com/file/mV3da
Please try and let us know if toolbox buttons are visible now.
thanks 3 users thanked Andrey Ivashov for this useful post.
on 16/10/2020(UTC),  on 16/10/2020(UTC),  on 18/10/2020(UTC)
Offline overlord
#29 Posted : 16 October 2020 00:37:10(UTC)
Turkey
All is working excepts those two characters.
Congrats, a long mystery is solved.
Clap Clapping Clap
By the way, maybe that's just my linux setup but;
If I use only the keyboard for "Evaluate symbolically (Ctrl+.)" it is not working too.
Button is fine for calculation, just keyboard combination doesn't work.
Edited by user 16 October 2020 00:45:02(UTC)  | Reason: Not specified
thanks 2 users thanked overlord for this useful post.
#30 Posted : 16 October 2020 01:47:19(UTC)
Great! Thank you!
This is because of Font missing some Greek symbols. Please try to write these chars in TextRegion and test different Fonts for this Region. I'm sure you will find some Fonts which will allow to render all Greek chars correctly.
on 16/10/2020(UTC)
Offline overlord
#31 Posted : 16 October 2020 04:08:47(UTC)
Turkey
Great! Thank you!
Yeap, you were right. I have copied courier font from windows font folder to linux now everything is in order.
Apparently free courier fonts are missing some characters. (which had derived from a previous archlinux setup)
There is no font or sidebar issue now as you can see.
Well, because I have grumpy and complainer personality I have seen another problem.
Bold and italic (and combined) is not working also.
Expressions should be italic and greek characters above is bold actually.
You can see this issue at picture below.
Regards.
Offline Eric Myers
#32 Posted : 16 October 2020 06:15:35(UTC)
Eric Myers
Was thanked: 4 time(s) in 4 post(s)
Andrey, I just want to say, thanks so much! This is a great help and I for one really appreciate you taking some time for us Linux oddballs!!
thanks 1 user thanked Eric Myers for this useful post.
on 16/10/2020(UTC)
Offline Eric Myers
#33 Posted : 16 October 2020 17:58:07(UTC)
Eric Myers
A non-manual fix for getting the right fonts that seems to have worked for me on Ubuntu:
sudo apt-get remove fonts-liberation2 fonts-liberation
sudo apt-get install ttf-mscorefonts-installer
Offline pdalet
#34 Posted : 16 October 2020 19:18:51(UTC)
pdalet
France, Metropolitan
Was thanked: 16 time(s) in 10 post(s)
I confirm that all works very well
Ubuntu 20.04 - 64 bits
Mono JIT compiler version 6.8.0.105 (Debian 6.8.0.105+dfsg-2 Wed Feb 26 23:23:50 UTC 2020)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
Interpreter: yes
LLVM: supported, not enabled.
Suspend: hybrid
GC: sgen (concurrent by default
Thanks a lot
Philippe DALET
Lyp Champollion
FIGEAC-FRANCE
Offline ElSid
#35 Posted : 16 October 2020 22:25:11(UTC)
ElSid
Overload, Eric, Pdalet,
Where did you post/upload your fonts in Linux? I am still seeing a mess and not all of the fonts. Being new to Linux, I'm now convinced this is an ID10T error.
I copied my windows 10 fonts directory into my home directory: home/{USR}/.local/share/fonts... unless they go somewhere else
Andrey and Davide,
Thank you for the quick resolution.
Offline Eric Myers
#36 Posted : 16 October 2020 22:39:13(UTC)
Eric Myers
Andrey and Davide,
Hi ElSid, what distribution do you use? The best way is probably to use your package manager if you can. I found a pretty good article that gives instructions for a few distributions: https://www.maketecheasier.com/install-microsoft-truetype-fonts-linux/.
I'm using Ubuntu, and it was pretty easy for me. I had to first remove the fonts-liberation2 and fonts-liberation packages, and then installed the ttf-mscorefonts-installer package.
Offline overlord
#37 Posted : 16 October 2020 23:00:52(UTC)
Turkey
Seems your font location is OK but it will be much more informative if you copy this command to terminal and show us the result.
Code:
fc-list | grep Courier
Maybe you need to force rebuild your font cache too. For this;
Code:
fc-cache -f
Offline waluyo
#38 Posted : 17 October 2020 18:08:10(UTC)
waluyo
Indonesia
I tried this build in my ubuntu 20.04
Mono JIT compiler version 6.12.0.90 (tarball Fri Sep 4 14:02:38 UTC 2020)
also showing the same thing, missing two Greeks characters.
Waluyo
Clap Clapping Clap
Offline overlord
#39 Posted : 17 October 2020 19:53:32(UTC)
Turkey
Waluyo
Look for Eric Myers post 4 or 5 above. He says those characters are fixed on his Ubuntu by using these commands.
Code:
Offline waluyo
#40 Posted : 18 October 2020 00:44:45(UTC)
waluyo
Indonesia
Yes I did try, but it did not help. Still missing the two characters.
regards,
waluyo
Waluyo
Code:
3 Pages<123>
