Hi, For my Physical Chemistry lectures I am adopting MathCAD 8th sheets attached to the Atkins and de Paula, 7th edition textbook, to the recent SMath Studio. For 3D plots I am applying plugin "3D Plot Region (Chart3DLi " it works good except saving formatted plots. Have you got any idea how to resolve the problem. The SMath sheet and PDF screen attached. Yours Dariusz. P701E02+.sm (29kb) downloaded 42 time(s). P701E02+.pdf (271kb) downloaded 37 time(s).
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
This is a version using the draw function of the Maxima plugin. The commands are described and demonstrated in Section 6.1 of the german SMath Handbuch P701E02_Kr.sm (225kb) downloaded 42 time(s). |
Thanks Martin, Now I have to overcome the "no maxima.bat" problem. . Your solution allows rotation of the plot? Dariusz
For configuring maxima, see the link in the signature.
The given solution controls the orientation by the view parameters. Yet there is a so called Maxima Draw3D region, where interactive rotation is possible, at the price of slightly less stability (the region might freeze). |
Originally Posted by: Dariusz Pogocki Now I have to overcome the "no maxima.bat" problem. . Your solution allows rotation of the plot? You can do it much differently and more profitable: 1. Tabulate a 10 x 10 xy matrix [per say] 2. Install the spline 2D 3. Mesh finer CreateMesh. 4. Orient at will. 5. Plot the 2D oriented. The bonus is that you can spline/interpolate the original matrix.
Hi! Maxima works after instalaton of the last, 64-bit version. The lectures I have for biology students, which are mathematically impaired (excluding statistics, which they learn but hate). Therefore I would like for them simplest possible solution, with "crude" SMath. Yours, Dariusz
Hi. You can adapt this technique to preserve the orientation in the 3D plot or plot the projection of a 3D surface into a 2D plot, both native SMath plots. The original idea isn't mine, but can't find from who I adapt it. Plot2DAs3D.sm (28kb) downloaded 45 time(s). Plot2DAs3D.pdf (127kb) downloaded 34 time(s).Best regards. Alvaro.
Originally Posted by: Dariusz Pogocki Hi! Maxima works after installaton of the last, 64-bit version. The lectures I have for biology students, which are mathematically impaired (excluding statistics, which they learn but hate). Therefore I would like for them simplest possible solution, with "crude" SMath. Yours, Dariusz Then the simplest is in native Smath ... ignoring Maxima. In the attached: spline(x,y,M) is same as bilinear(x,y,M) spline(x,y,M) adapted from Valery Ochov [MCD] Spline Matrix Tutorial RECTANGULAR Surface Plot.sm (23kb) downloaded 31 time(s). SplineRectangularMatrix1 Rotate XYZ.sm (55kb) downloaded 29 time(s). Bilinear [Oterwise metric X, Y Directions].sm (78kb) downloaded 27 time(s).
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
Originally Posted by: Razonar Hi. You can adapt this technique to preserve the orientation in the 3D plot or plot the projection of a 3D surface into a 2D plot, both native SMath plots. The original idea isn't mine, but can't find from who I adapt it. Alvaro,perhaps you got this idea from here https://en.smath.com/for...-dimensional--graph.aspx
1 user thanked Ber7 for this useful post.
Originally Posted by: Ber7 Originally Posted by: Razonar Hi. You can adapt this technique to preserve the orientation in the 3D plot or plot the projection of a 3D surface into a 2D plot, both native SMath plots. The original idea isn't mine, but can't find from who I adapt it. Alvaro,perhaps you got this idea from here https://en.smath.com/for...-dimensional--graph.aspx Hi Fridel. Sure from you, but not from this post, which involve very complicate figures. I remember that I ask from another post (I assume now to you) from where you get that gamma factor for rotate the matrix to plot, because have troubles reconstructing it. In spanish literature spherical coordinates and Euler angles are not always the same than in english, and given that SMath 3D plots are left oriented ... with this two issues I have enough. BTW the idea for multiply with a "point of view" matrix it's great and works for make 3D plots in native SMath 2D plot region, or preserve the orientation in 3D. I remember also another post, guess from Jean, with other matrices expressing very simple rotations with integers as coefficients. Best regards. Alvaro.
Originally Posted by: Dariusz Pogocki For 3D plots I am applyingplugin "3D Plot Region (Chart3DLi" it works good except saving formatted plots. Have you got any idea how to resolve the problem. Considered a bug, reported, never solved ... plugin as is can't mesh, does not save setting => useless. Practice the attached. Page2 Unk.sm (37kb) downloaded 28 time(s).
Originally Posted by: Razonar from where you get that gamma factor for rotate the matrix to plot, because have troubles reconstructing it. That gamma factor is the Euler [roll, pitch, yaw] NOT commutative, otherwise: couldn't pilot aircraft !!! The MeshPlot(T(u,v),0,2*π,35,0,2*π,35) is CreateMesh(,,,,,,,) since at least SS 5346 The attached is Alvaro document optimized SS 6179 Once optimized, it runs ~ 10 times faster but twice timing than CreateMesh. There are 4 common rotations: 1. Quaternions, 2. Parametric 'X,Y,Z,t' 3. Euler 4. Composite If you want those demo sheets: say YES. Cheers, thanks alvaro ... Jean Utilities Matrix CreateMesh Code [Alvaro].sm (43kb) downloaded 36 time(s).
