Hello guys, I want to create a while loop which compare two Results and if the difference is too high(more than 0,1), the second result should turn into the first and the second should be calculated again. But I just create an endless loop or a loop which is calculated just one time. Can someone give me some recommendation? Thanks a lot. twaddex iteration.sm (30kb) downloaded 13 time(s).
ϑ'o(ϑGS)=f(x) Given f(x) some value, you can solve for (x). Before solving => always plot. do=0.4591 is way below the flat region. iteration.sm (32kb) downloaded 9 time(s).
... suite, The doctored solved from before can be viewed globally via inversing. Your function is too complicated, it will have no inverse. It can be inversed recursively and plotted data points or spline smooth. Such a monster big function w/o abstract ... what do you think ?
