Offline pdalet
#1 Posted : 10 November 2019 12:54:22(UTC)
pdalet
Rank: Member
France, Metropolitan
Was thanked: 10 time(s) in 6 post(s)
Hello Andrey
I launch smathstudio 7251 on Ubuntu 16.04 and 18.04 (64 bits): It crashes.
mono version used: Mono JIT compiler version 6.4.0.198 (tarball Tue Sep 24 01:20:30 UTC 2019)
Before 7250, it ran well.
Philippe
administrateur@HP-ProBook-6570b:~/Téléchargements/SMathStudioDesktop.0_99_7251.Mono$ ./smathstudio_desktop_mono
- [AppDir] SpecialFunctions 1.12.7251.32800 (12 ms.)
- [AppDir] XMCDFileType 1.12.7251.32800 (2 ms.)
- [AppDir] StandardToolboxButtons 1.1.7251.32800 (0 ms.)
- [AppDir] TextRegion 1.11.7251.32800 (5 ms.)
- [AppDir] HTMLFileType 1.14.7251.32800 (1 ms.)
- [AppDir] PictureRegion 1.10.7251.32800 (1 ms.)
- [AppDir] PlotRegion 1.11.7251.32800 (5 ms.)
- [AppDir] SMath Viewer Files Plugin 1.1.7251.32841 (1 ms.)
- [AppDir] ImageFileType 1.11.7251.32800 (0 ms.)
- [AppDir] SMathFileType 1.11.7251.32800 (0 ms.)
Unhandled Exception:
System.EntryPointNotFoundException: GetKeyboardState assembly:<unknown assembly> type:<unknown type> memberSadnull)
at (wrapper managed-to-native) ..(byte[])
at .. (System.Windows.Forms.Keys ) [0x0000b] in <8798750fc7d24db088010d856e23bb95>:0
at .. (System.Text.RegularExpressions.Match ) [0x00020] in <8798750fc7d24db088010d856e23bb95>:0
at System.Text.RegularExpressions.Regex.Replace (System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.Regex regex, System.String input, System.Int32 count, System.Int32 startat) [0x00094] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Int32 count, System.Int32 startat) [0x0000e] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00023] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.RegexOptions options, System.TimeSpan matchTimeout) [0x0000a] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00000] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at .. (System.Collections.Generic.IList`1[T] ) [0x000a1] in <8798750fc7d24db088010d856e23bb95>:0
at .. () [0x000a8] in <8798750fc7d24db088010d856e23bb95>:0
at .. () [0x0075b] in <8798750fc7d24db088010d856e23bb95>:0
at ...ctor (SMath.Manager.SessionProfile ) [0x0020d] in <8798750fc7d24db088010d856e23bb95>:0
at (wrapper remoting-invoke-with-check) ...ctor(SMath.Manager.SessionProfile)
at SMath.UI.Desktop.MainForm. (System.Object , System.EventArgs ) [0x00285] in <8798750fc7d24db088010d856e23bb95>:0
at SMath.UI.Desktop.MainForm. () [0x005b0] in <8798750fc7d24db088010d856e23bb95>:0
at SMath.UI.Desktop.MainForm..ctor (System.Collections.Generic.List`1[T] , System.Boolean ) [0x0061a] in <8798750fc7d24db088010d856e23bb95>:0
at (wrapper remoting-invoke-with-check) SMath.UI.Desktop.MainForm..ctor(System.Collections.Generic.List`1<string>,bool)
at SMath.UI.Desktop.Program. (System.String[] ) [0x0009a] in <8798750fc7d24db088010d856e23bb95>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.EntryPointNotFoundException: GetKeyboardState assembly:<unknown assembly> type:<unknown type> memberSadnull)
#2 Posted : 14 November 2019 01:21:34(UTC)
Was thanked: 796 time(s) in 630 post(s)
That one is for Andrey, however ...
What I know from experience is about a new version of some software.
Before installing a new version of "JoBo" software,
you must evaporate previous "JoBlo" from the PC.
Evaporation is via regedit to access Windows registry.
From there, you delete all items "JoBlo, not always easy
to recognize unless identified otherwise by supplier.
Remove program from other Windows does not evaporate,
it just deactivate ...
The question is: were is the Smath evaporation procedure ?
Sorry, can't help more.
Offline mkraska
#3 Posted : 26 January 2020 20:13:07(UTC)
mkraska
Was thanked: 878 time(s) in 557 post(s)
I confirm the problem with 7251 on Kubuntu 19.10 with fresh mono-complete package.
EDIT: 7030 works.Just trying the plugins...
Edited by user 26 January 2020 20:17:39(UTC)  | Reason: Not specified
#4 Posted : 27 January 2020 00:46:51(UTC)
That's the right answer: 7030 is the latest stable version.
There are few other stable versions ... 6179 typical glorious !
What is not tutored is how to evaporate an existing version.
i.e: render PC virgin of Smath like it had never existed,
install latest stable 7030
Just comments ... back to work.
Offline Andrey Ivashov
#5 Posted : 15 September 2020 00:52:21(UTC)
Was thanked: 1654 time(s) in 553 post(s)
Offline Mikhail
#6 Posted : 15 September 2020 10:08:21(UTC)
Mikhail
Hello
Originally Posted by: Andrey Ivashov Go to Quoted Post
How can I get the fixed version?
Offline Eric Myers
#7 Posted : 17 September 2020 22:54:39(UTC)
Eric Myers
Rank: Member
Yes please, I'm looking forward to it as well, thanks--
Offline alyles
#8 Posted : 18 September 2020 19:56:37(UTC)
alyles
Was thanked: 71 time(s) in 45 post(s)
Did you try the latest stable release? https://smath.com/file/v...op.0_99_7561.Mono.tar.gz
Offline Eric Myers
#9 Posted : 18 September 2020 20:56:06(UTC)
Eric Myers
Rank: Member
Yes, it crashes after the splash screen. Here's some of my info:
OS is Kubuntu 18.04
Mono version info:
Code:
~$ mono --version
Mono JIT compiler version 6.12.0.90 (tarball Fri Sep  4 14:01:23 UTC 2020)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
        TLS:           __thread
        SIGSEGV:       altstack
        Notifications: epoll
        Architecture:  amd64
        Disabled:      none
        Misc:          softdebug
        Interpreter:   yes
        LLVM:          yes(610)
        Suspend:       hybrid
        GC:            sgen (concurrent by default)
Terminal output from attempt to run SMath:
Code:
~/SMathStudioDesktop.0_99_7561.Mono$ ./smathstudio_desktop_mono
(mono:15774): Gtk-WARNING **: 12:45:22.270: Unable to locate theme engine in module_path: "adwaita",
(mono:15774): Gtk-WARNING **: 12:45:22.275: Unable to locate theme engine in module_path: "adwaita",
- [AppDir] SpecialFunctions 1.12.7561.40250 (3 ms.)
- [UserDir] Conditionally Formatted Label 1.0.7480.25296 (2 ms.)
- [UserDir] RadioButtonList Region 1.0.7480.25320 (2 ms.)
- [UserDir] Data Exchange 1.1.6858.3747 (7 ms.)
- [UserDir] Table Region 0.3.7557.19317 (2 ms.)
- [AppDir] SMathFileType 1.11.7561.40250 (0 ms.)
- [AppDir] ViewerFileType 1.1.7561.40250 (0 ms.)
- [AppDir] StandardToolboxButtons 1.1.7561.40250 (1 ms.)
- [AppDir] PlotRegion 1.11.7561.40250 (2 ms.)
- [AppDir] HTMLFileType 1.14.7561.40250 (0 ms.)
- [AppDir] XMCDFileType 1.12.7561.40250 (1 ms.)
- [AppDir] PictureRegion 1.10.7561.40250 (1 ms.)
- [AppDir] TextRegion 1.11.7561.40250 (1 ms.)
- [AppDir] ImageFileType 1.11.7561.40250 (0 ms.)
System.EntryPointNotFoundException: GetKeyboardState assembly:<unknown assembly> type:<unknown type> member:(null)
  at .. (System.Windows.Forms.Keys ) [0x0000b] in <96ec79978efd4109963dd12019ab1382>:0
  at .. (System.Text.RegularExpressions.Match ) [0x00020] in <96ec79978efd4109963dd12019ab1382>:0
  at System.Text.RegularExpressions.Regex.Replace (System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.Regex regex, System.String input, System.Int32 count, System.Int32 startat) [0x00094] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Int32 count, System.Int32 startat) [0x0000e] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00023] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.RegexOptions options, System.TimeSpan matchTimeout) [0x0000a] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00000] in <3d97dda773a54430b892e1d794e5d921>:0
  at .. (System.Collections.Generic.IList`1[T] ) [0x000a1] in <96ec79978efd4109963dd12019ab1382>:0
  at .. () [0x000a8] in <96ec79978efd4109963dd12019ab1382>:0
  at .. () [0x0075b] in <96ec79978efd4109963dd12019ab1382>:0
  at ...ctor (SMath.Manager.SessionProfile ) [0x0020d] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.MainForm. (System.Object , System.EventArgs ) [0x00285] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.MainForm. () [0x005b0] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.MainForm..ctor (System.Collections.Generic.List`1[T] , System.Boolean ) [0x0061a] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.Program. (System.String[] ) [0x0009a] in <96ec79978efd4109963dd12019ab1382>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.EntryPointNotFoundException: GetKeyboardState assembly:<unknown assembly> type:<unknown type> member:(null)
