Offline Andrey Ivashov
#1 Posted : 25 August 2020 02:24:09(UTC)
Was thanked: 1972 time(s) in 661 post(s)
New Beta SMath Studio 0.99.7542 is available!
SMath Studio boxCalculation of Gravitation Acceleration exampleExample of animation on the WorksheetExtensions Manager toolOpened math Reference BookSMath Viewer output to Autocad exampleSMath Studio on iOSSMath Studio on iPad
Changes introduced in current build
Improvements
  • COUNT and PAGENUM fields improved to allow setting up an offset for the output number;
  • Alignment context menu item added to TextRegion;
  • TextRegion improved to support changing Line spacing using context menu.
Corrections
  • trunc() function does not accept units in the argument anymore;
  • Empty Heder/Footer supported now;
  • Basic behaviors of the TextRegion improved (text selections);
  • SS-4612 Line wrapping significantly improved in TextRegion;
  • Fixed "There is no xml start tag" issue happens when self-closed tag of the Region was included into *.sm(z) file;
  • Functionality of the " " (space) key fixed in case when no plug-in for Text Region is available;
  • equrep() function supports variables/functions replacements now.
Miscellaneous
  • Support for .Net Core 3.1 implemented (app is still released supporting .Net 2.0 for now);
  • Refactoring.
Download
Software icon SMathStudioDesktop.0_99_7542.Setup.msi (Date: 2020.08.25; File size: 2.28 MB) - 1530 downloads
Software icon SMathStudioDesktop.0_99_7542.Mono.tar.gz (Date: 2020.08.25; File size: 1.4 MB) - 257 downloads
Edited by user 20 June 2022 14:44:23(UTC)  | Reason: Not specified
thanks 10 users thanked Andrey Ivashov for this useful post.
on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 26/08/2020(UTC),  on 26/08/2020(UTC),  on 28/08/2020(UTC),  on 20/09/2020(UTC)
Offline Razonar
#2 Posted : 25 August 2020 12:26:19(UTC)
Razonar
Uruguay
Was thanked: 674 time(s) in 421 post(s)
Hi. Thanks! Very much!
"equrep() function supports variables/functions replacements now."
Any example about what that means?
Also, I see that this error persists:
#3 Posted : 26 August 2020 00:07:08(UTC)
Hello Alvaro!
Yes, this is a main reason why I can't release stable version of SMath Studio now. I'm working on this issue right now.
on 26/08/2020(UTC)
#4 Posted : 27 August 2020 23:11:26(UTC)
Was thanked: 941 time(s) in 769 post(s)
Any example about what that means ?
Can you show an application of it ?
An image is good enough.
Thanks ... Jean
Offline Razonar
#5 Posted : 28 August 2020 03:24:31(UTC)
Razonar
Uruguay
Thanks ... Jean
Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.
on 28/08/2020(UTC),  on 29/08/2020(UTC)
#6 Posted : 29 August 2020 12:54:30(UTC)
Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides.
Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again.
So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important.
on 29/08/2020(UTC),  on 29/08/2020(UTC),  on 29/08/2020(UTC),  on 30/08/2020(UTC)
#7 Posted : 30 August 2020 18:12:30(UTC)
Thanks Alvaro ... always there in Smath Community !
BTW Andrey, if/else, if/otherwise have not been observed
detrimental in timing in general applications.
For this application [Julia], timing kills Smath ... Oh !
OK, my Win 7 1.66 GHz is steam engine.
What about your latest Beta SS 7542 ?
Thanks ... Jean
Pattern Julia Set [PUBLISH].sm (173kb) downloaded 26 time(s).
Offline overlord
#8 Posted : 30 August 2020 22:33:41(UTC)
Turkey
Was thanked: 406 time(s) in 273 post(s)
Maybe it is a bug maybe intended I don't know;
On 7542 for underlined text regions, spaces are not underlined.
No problem for letters, numbers, punctuations, etc.
Writer regions don't have this issue.
Offline mkraska
#9 Posted : 09 September 2020 18:12:34(UTC)
mkraska
Was thanked: 999 time(s) in 639 post(s)
I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542.
In 7251 this still works. It also works for documents produced in 7542.
Edited by user 09 September 2020 18:15:20(UTC)  | Reason: Not specified
#10 Posted : 10 September 2020 01:32:12(UTC)
Thank you! Fixed.
#11 Posted : 10 September 2020 01:33:22(UTC)
I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
Offline mkraska
#12 Posted : 10 September 2020 13:16:24(UTC)
mkraska
I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed.
If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry.
Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour.
7542 displays existing files correctly. Just no access to this one setting.
I leave out the maxima draw region, as this might prevent reproduction without maxima installation.
border 7542.sm (8kb) downloaded 16 time(s).
border 7542 then 7251.sm (8kb) downloaded 18 time(s).
on 13/09/2020(UTC)
#13 Posted : 13 September 2020 13:35:16(UTC)
Thank you very much. Fixed now.
There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out.
on 14/09/2020(UTC)
#14 Posted : 13 September 2020 22:55:14(UTC)
Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example.
This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart.
on 13/09/2020(UTC)
Offline mkraska
#15 Posted : 14 September 2020 01:00:12(UTC)
mkraska
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint!
Filed in the bug tracking system as SS-4640
Offline Razonar
#16 Posted : 17 September 2020 00:43:50(UTC)
Razonar
Uruguay
I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)"
Here my attempt to convert an expression with operators to an expression with binary or unary functions only
_to_expr.sm (52kb) downloaded 15 time(s).
_to_expr.pdf (224kb) downloaded 23 time(s).
Offline Razonar
#17 Posted : 31 October 2021 02:11:38(UTC)
Razonar
Uruguay
Rematch ... It's seems to work now.
num2expr.sm (40kb) downloaded 12 time(s).
num2expr.pdf (177kb) downloaded 23 time(s).
on 31/10/2021(UTC)
