Offline Andrey Ivashov
#1 Posted : 25 August 2020 02:24:09(UTC)
Was thanked: 1977 time(s) in 665 post(s)
SMath Studio - SMath
Created by Andrey Ivashov in the scope of SMath project. Published by smath.
SMath Studio box
Version 1.0.8348 - Stable (released at )
Downloads: 1698773 Download
Open in browser
Changes history
La aparición del proyecto Smath, cubre un vacío que existía en el ámbito del software gratuito para Ingeniería. Es un proyecto que llegó para quedarse, ya que permite logros muy buenos a quienes utilizan esta herramienta. felicitaciones a Andrey y el gran equipo de colaboradores que cada uno con su aporte desinteresado hacen crecer esta aplicación que ya podemos caratular como de uso profesional more...
by Ing Parcelo Ortiz Plá
Great program for conducting engineering calculations. The ability to insert text blocks and pictures makes it perfect for both computation and communication of the results to colleagues. more...
by Filip Finodeyev
As a civil engineer, over the years I have frequently used MathCAD for not only performing but also documenting calculations. With PTC dropping perpetual licensing, my recommendation to all the junior engineers I train is to give SMath Studio a serious look. While not a turnkey replacement for MathCAD, it provides most of the functionality and power at an incredible price. Already a wonderful program filling a key niche spot between a numerical calculator like Octave, and a CAS like Maxima, the expanding plugin and 3rd party development is on the rise and this project's future keeps getting even brighter. Much consideration must be given by any engineer or business before they settle on a software for adopting into the workflow. Although not open-source in the strictest sense, the development community is similar to what you would find in any first class OSS software project. The current owner of the SMath Project has also agreed to release the source code under open source license should he not be able to continue the project. So do not let the cost (your time) of learning SMath Studio and migrating your MathCAD computation sheets scare you. This project is here to stay. more...
by Michael Fuller, P.E., PMP
Edited by user 20 June 2022 14:44:23(UTC)  | Reason: Not specified
thanks 10 users thanked Andrey Ivashov for this useful post.
on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 25/08/2020(UTC),  on 26/08/2020(UTC),  on 26/08/2020(UTC),  on 28/08/2020(UTC),  on 20/09/2020(UTC)
Offline Razonar
#2 Posted : 25 August 2020 12:26:19(UTC)
Razonar
Uruguay
Was thanked: 728 time(s) in 460 post(s)
Hi. Thanks! Very much!
"equrep() function supports variables/functions replacements now."
Any example about what that means?
Also, I see that this error persists:
#3 Posted : 26 August 2020 00:07:08(UTC)
Hello Alvaro!
Yes, this is a main reason why I can't release stable version of SMath Studio now. I'm working on this issue right now.
on 26/08/2020(UTC)
#4 Posted : 27 August 2020 23:11:26(UTC)
Was thanked: 959 time(s) in 787 post(s)
Any example about what that means ?
Can you show an application of it ?
An image is good enough.
Thanks ... Jean
Offline Razonar
#5 Posted : 28 August 2020 03:24:31(UTC)
Razonar
Uruguay
Thanks ... Jean
Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.
on 28/08/2020(UTC),  on 29/08/2020(UTC)
#6 Posted : 29 August 2020 12:54:30(UTC)
Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides.
Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again.
So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important.
on 29/08/2020(UTC),  on 29/08/2020(UTC),  on 29/08/2020(UTC),  on 30/08/2020(UTC)
#7 Posted : 30 August 2020 18:12:30(UTC)
Thanks Alvaro ... always there in Smath Community !
BTW Andrey, if/else, if/otherwise have not been observed
detrimental in timing in general applications.
For this application [Julia], timing kills Smath ... Oh !
OK, my Win 7 1.66 GHz is steam engine.
What about your latest Beta SS 7542 ?
Thanks ... Jean
Pattern Julia Set [PUBLISH].sm (173kb) downloaded 26 time(s).
Offline overlord
#8 Posted : 30 August 2020 22:33:41(UTC)
Turkey
Was thanked: 444 time(s) in 298 post(s)
Maybe it is a bug maybe intended I don't know;
On 7542 for underlined text regions, spaces are not underlined.
No problem for letters, numbers, punctuations, etc.
Writer regions don't have this issue.
Offline mkraska
#9 Posted : 09 September 2020 18:12:34(UTC)
mkraska
Was thanked: 1056 time(s) in 676 post(s)
I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542.
In 7251 this still works. It also works for documents produced in 7542.
Edited by user 09 September 2020 18:15:20(UTC)  | Reason: Not specified
#10 Posted : 10 September 2020 01:32:12(UTC)
Thank you! Fixed.
#11 Posted : 10 September 2020 01:33:22(UTC)
I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
Offline mkraska
#12 Posted : 10 September 2020 13:16:24(UTC)
mkraska
I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed.
If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry.
Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour.
7542 displays existing files correctly. Just no access to this one setting.
I leave out the maxima draw region, as this might prevent reproduction without maxima installation.
border 7542.sm (8kb) downloaded 16 time(s).
border 7542 then 7251.sm (8kb) downloaded 18 time(s).
on 13/09/2020(UTC)
#13 Posted : 13 September 2020 13:35:16(UTC)
Thank you very much. Fixed now.
There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out.
on 14/09/2020(UTC)
#14 Posted : 13 September 2020 22:55:14(UTC)
Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example.
This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart.
on 13/09/2020(UTC)
Offline mkraska
#15 Posted : 14 September 2020 01:00:12(UTC)
mkraska
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint!
Filed in the bug tracking system as SS-4640
Offline Razonar
#16 Posted : 17 September 2020 00:43:50(UTC)
Razonar
Uruguay
I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)"
Here my attempt to convert an expression with operators to an expression with binary or unary functions only
_to_expr.sm (52kb) downloaded 15 time(s).
_to_expr.pdf (224kb) downloaded 23 time(s).
Offline Razonar
#17 Posted : 31 October 2021 02:11:38(UTC)
Razonar
Uruguay
Rematch ... It's seems to work now.
num2expr.sm (40kb) downloaded 12 time(s).
num2expr.pdf (177kb) downloaded 23 time(s).
on 31/10/2021(UTC)
