SMath Studio Forum
Samples
Surface scanning experiments
Hello all! Today I've tested SMath Studio graphs. Examples I've used I found here: twt.mpei.ac.ru/ochkov/Lace/Lace.htm I just improved the logic a bit and made common function for such surfaces scanning. Below you can find screenshot and the file I've worked with. ( download the worksheet) Regards.
on 28/01/2012(UTC), on 30/01/2012(UTC)
Joined: 04/07/2010(UTC) Posts: 178 Was thanked: 19 time(s) in 13 post(s)
Andrey, The plugins you're using appear to be newer than the ones that were distributed with SMath 0.90. I can't run your example. And I think AreaRegion is now builtin to SMath a plugin is no longer required? Edited by user 28 January 2012 03:12:51(UTC)
Ed |
Yes, I've created that file using newer version but you still can open it by 0.90 (checked) - just press "yes" in the dialog on application start. Note that accuracy (the last argument of the scanSurface() function in the file is smaller then I've shown on screenshot).
Regards.
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
1 user thanked Ber7 for this useful post.
SMath Studio Forum
Samples
