Offline magnus
#1 Posted : 31 July 2020 23:46:34(UTC)
magnus
Peru
how to clear a variable in an equation, for example P.V = R.T.n, how to make the variable "T" appear, is there a command that does that?,
#2 Posted : 01 August 2020 13:57:58(UTC)
Was thanked: 959 time(s) in 787 post(s)
Offline PompelmoTell
#3 Posted : 01 August 2020 14:20:09(UTC)
PompelmoTell
I hope I understand the problem
magnus_01.sm (5kb) downloaded 34 time(s).
you need to install the Maxima plugin (and have Maxima installed)
Offline magnus
#4 Posted : 02 August 2020 06:29:42(UTC)
magnus
Peru
I opened the file, but I get this "Initializing error. Please check path to Maxima under Insert> Maxima> Settings.",
I have wxMaxima installed and also the Maxima plugin on Smath
Similar Topics
Symbolic calculation - Save the current result (Questions)
by Raztua 14/07/2023 00:49:43(UTC)
Symbolic calculation versus numeric calculation (Bugs & Problems)
by sleschke 06/02/2009 16:17:05(UTC)
