how to clear a variable in an equation, for example P.V = R.T.n, how to make the variable "T" appear, is there a command that does that?,
Joined: 04/07/2015(UTC) Posts: 6,321  Was thanked: 918 time(s) in 746 post(s)
Joined: 23/12/2011(UTC) Posts: 308   Location: italy Was thanked: 106 time(s) in 90 post(s)
I hope I understand the problem magnus_01.sm (5kb) downloaded 33 time(s).you need to install the Maxima plugin (and have Maxima installed) sergio
Originally Posted by: PompelmoTell  I hope I understand the problem magnus_01.sm (5kb) downloaded 33 time(s).you need to install the Maxima plugin (and have Maxima installed) sergio I opened the file, but I get this "Initializing error. Please check path to Maxima under Insert> Maxima> Settings.", I have wxMaxima installed and also the Maxima plugin on Smath
