Hi. sum have an issue for symbolics evaluations. Best regards. Alvaro.
Just check , Alvaro. Between yourself and me ... we are old kookoo in those games !
Joined: 23/07/2013(UTC) Posts: 1,126 Was thanked: 507 time(s) in 338 post(s)
Originally Posted by: Razonar Hi. sum have an issue for symbolics evaluations.
Best regards. Alvaro. You are correct, bug reproduced. Definitely there are some issues. Perhaps it is not only sum related too.
Hi. Thanks Overlord. I don't see these other problem. What make troubles for me is the fact that sum don't returns the symbolic values but numerical approximations, in this case for sqrt(17). I expect to see sum(vec) = 5/sqrt(17) instead the rational showed. I introduce the "x" value just for check if sum have some eval() function somewhere. But then ... ups, another issue simplifying 1+4.
sum.sm (12kb) downloaded 10 time(s). |
I see no bug ... NOBUG.sm (31kb) downloaded 13 time(s).
Hi. Some notes attached. sum.sm (21kb) downloaded 11 time(s). sum.pdf (67kb) downloaded 17 time(s).Best regards. Alvaro.
