5 Pages«<2345>
Offline Razonar
#61 Posted : 26 November 2019 11:03:00(UTC)
Razonar
Uruguay
Was thanked: 807 time(s) in 509 post(s)
Originally Posted by: veb Go to Quoted Post
Hello!
Sometimes you want the calculation to show by which formula the calculations were performed.
With some limitations, you can do that with this.
combo.sm (5kb) downloaded 56 time(s).
Offline veb
#62 Posted : 26 November 2019 11:36:47(UTC)
veb
Thanks.
It works and maybe it will be enough.
But anyway, adding the ability to fomatted label would be great, then this definitely closed this issue
#63 Posted : 26 November 2019 16:38:57(UTC)
Was thanked: 975 time(s) in 803 post(s)
Sometimes you want the calculation to show by which formula the calculations were performed. Use for this combo boxlist is not beautiful. Formatted label would be more accurate. But Formatted Label does not display a formalized formula. Is it possible to add such a possibility to the formatted label? And in addition, the ability to remove the frame around the edges of the formatted label?
T
Formatted Label is superb for official document,
meets all demands. Maybe except for ComboBox.
I don't even know what ComboBox was invented for.
Done SS 6179 ... please report if red in your SS version.
The graph is done outside, on the RHS, then slided-in.
Image Formated LABEL [Oxyhemoglobin].sm (18kb) downloaded 86 time(s).
#64 Posted : 24 December 2019 20:37:34(UTC)
Was thanked: 1322 time(s) in 872 post(s)
Beta PLUGIN UPDATED SMath Studio 0.99.7250 and later
  • content of strings starting with s: is now rendered as math object;
on 24/12/2019(UTC)
#65 Posted : 24 June 2020 14:09:58(UTC)
PLUGIN UPDATED SMath Studio 0.99.7251 and later
  • Enhanced alignments of embedded MathRegions;
  • The menu button is now within the "Controls" group;
Edited by user 04 July 2020 23:22:07(UTC)  | Reason: Not specified
on 25/06/2020(UTC)
Offline Jason McCool
#66 Posted : 14 October 2020 00:38:18(UTC)
Jason McCool
Was thanked: 9 time(s) in 7 post(s)
I've really been getting some good use out of this plugin for pass/fail warnings on calcs, but here's a question. I tried using a check mark and X in an if statement in the label, and it displayed correctly in the if statement but not in the result. This was using the Segoe UI Symbol font. First I'd copied and pasted from Windows Character Map and the output was just the unicode number for that symbol. I went to Settings and changed the font to Segoe UI Symbol to see if that would help but it didn't. Is this something that is possible? Thanks!
Jason McCool
Robbins Engineering
Little Rock, AR, USA
#67 Posted : 14 October 2020 14:47:18(UTC)
Thank you Jason, I think that I've missed to implement it in some branch of the code, I'll fix it ASAP.
#68 Posted : 14 October 2020 14:51:03(UTC)
About CharMap, you have to experiment several up until you get the
appropriate character instead of Unicode.
For direct calculations, Smath error message is sufficient.
You can't really trace from within program, not even Mathcad 11.
Calculations may have passed but so wrong !
#69 Posted : 14 October 2020 18:33:05(UTC)
Not sure what you are after ?
#70 Posted : 15 October 2020 02:15:48(UTC)
Just released a fix, it should works now.
on 15/10/2020(UTC),  on 15/10/2020(UTC)
#71 Posted : 15 October 2020 21:53:42(UTC)
Jason McCool
Works great now - Thanks!
Clap
Jason McCool
Robbins Engineering
Offline ZehKraudio
#72 Posted : 19 April 2021 17:09:42(UTC)
ZehKraudio
Brazil
Hello everyone! I am new to SMATH and I am loving it... After reading thru this post, and experimenting with the plugin, I am still missing some instructions or user manual. I could achieve the following but I am not sure about the available options and maybe other features...733_602_1.png
#73 Posted : 19 April 2021 17:47:55(UTC)
Hello ZehKraudio Offline ,
the first post has an attachment (right above the picture) that conatains the documentation about this plugin.
Context menu (right click on the region) has the option to show or hide the border, as well as the link for the font dialog (that can be opened by double-click on the region).
Styles are listed in the documentation (I noticed it is a bit outdated, they are no longer case-sensitive).
Edited by user 19 April 2021 17:53:33(UTC)  | Reason: Not specified
#74 Posted : 19 April 2021 18:44:47(UTC)
Visit Samples few days ago for more options ... convert num2symbols
Offline Kenny Lemens
#75 Posted : 07 April 2022 19:03:52(UTC)
Kenny Lemens
Was thanked: 56 time(s) in 35 post(s)
Greetings,
I have a feature request:
- Include an option: allow user to 'Hide label from SMath Viewer'
Two reasons:
1) Allows a user to add comments within a worksheet that does not get published to the Viewer (akin to commenting code in C++ or VB.net)
2) For testing/debugging label(s) and how they work, how they display within the Viewer.
- - - - Per an image you posted (see below): I would like the ability to hide several of those buttons without deleting them from the worksheet itself. (NOTE: I am aware that disabling the control does has this effect; however, it also disables its evaluation in the worksheet; it would be nice to interact with an enabled Label within the worksheet, but to toggle hide/show when publishing to the SMath viewer.
Originally Posted by: Davide Carpi Go to Quoted Post
Quote=Davide Carpi;11378
Thoughts?
Thank you
-Kenny Lemens; P.E.
#76 Posted : 13 April 2022 20:12:54(UTC)
Done, the feature is available through context menu (default is visible).
A general way to keep regions and not display them in viewer is to organize the regions to hide in dedicated areas to collapse before publishing as exe.
Edited by user 14 April 2022 00:38:29(UTC)  | Reason: Not specified
#77 Posted : 14 April 2022 00:47:09(UTC)
Kenny Lemens
Thank you! Such a minor feature, but I appreciate the implementation.
-Kenny Lemens, P.E.
Offline GermanJG
#78 Posted : 17 January 2023 01:21:00(UTC)
GermanJG
Argentina
Hello, i am having problems with this plugin or i dont exactly kown if the problem is the plugin.
I attach images that can explain the situation better than my words.
When i define the same value manually the warning disappears
Offline ndtma
#79 Posted : 17 January 2023 06:14:36(UTC)
ndtma
Sri Lanka
Was thanked: 124 time(s) in 82 post(s)
Hello. Better if you post the sm file, for anybody to check.
thanks 1 user thanked ndtma for this useful post.
on 17/01/2023(UTC)
#80 Posted : 17 January 2023 14:42:51(UTC)
Originally Posted by: GermanJG Go to Quoted Post
Hello, I am having problems with this plugin or I don't exactly know if the problem is the plugin.
Formatted Label supports conditional, providing set correctly.
Image Formated LABEL [Oxyhemoglobin] FORUM.sm (17kb) downloaded 10 time(s).
Similar Topics
Conditionally Formatted Labels vs Insert Writer Region (Questions)
by Fran_3 11/11/2021 20:27:23(UTC)
5 Pages«<2345>
