  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,321   Location: Italy Was thanked: 1167 time(s) in 768 post(s)
PLUGIN UPDATED SMath Studio 0.97.5346 and later- Fixed content update in SMath Viewer; - Added context menu item to access settings' form; Please note: if you use symbolic data as content and the content changes, this may mess up the form layout (as for now a feature to refresh the whole layout of the viewer is not available). Edited by user 11 March 2016 01:47:08(UTC)
Joined: 27/05/2016(UTC) Posts: 27   Location: Little Rock, Arkansas Was thanked: 4 time(s) in 4 post(s)
Thank you very much for this plugin. I have been using it for several of my engineering worksheets for several months now and find it very useful. I notice it does not show up under the plugins tab of the Extensions Manager like it did when I first installed it. Is this still being developed? If so, is there a way to be able to change the width of the ComboListBox? The Combobox function has resizing grips, but doesn't include a dropdown list that I really need, like your plugin does. Is that something could be added, either through grips, or through an additional width parameter in the Settings dialog? Thank you again for all your hard work!
Jason |
Jason McCool Robbins Engineering Little Rock, AR, USA |
Originally Posted by: Jason McCool  Thank you very much for this plugin. I have been using it for several of my engineering worksheets for several months now and find it very useful. You're very welcome Jason  Originally Posted by: Jason McCool  I notice it does not show up under the plugins tab of the Extensions Manager like it did when I first installed it. Is this still being developed? I'm not sure on what you mean here, but if you mean that there aren't updates in the "Online gallery" is only because there weren't reports of bugs or new features added. But yes, the plugin is under development. Originally Posted by: Jason McCool  If so, is there a way to be able to change the width of the ComboListBox? The Combobox function has resizing grips, but doesn't include a dropdown list that I really need, like your plugin does. Is that something could be added, either through grips, or through an additional width parameter in the Settings dialog? Maybe... the main problem is just about the minimum width, because I can't add ellipsis to truncate "properly" math objects; I'll see what I can do... |
PLUGIN UPDATED SMath Studio 0.99.7251 and later- Enhanced alignments of embedded MathRegions;
Joined: 12/02/2018(UTC) Posts: 30   Location: Belém Was thanked: 2 time(s) in 1 post(s)
Hi! The description of a ComboBoxList region can't be moved around or resized. Same problem in the Numeric UpDown region.
Originally Posted by: joaobr  Hi! The description of a ComboBoxList region can't be moved around or resized. Same problem in the Numeric UpDown region. Hello
joaobr
, confirmed. It is probably because these regions have fixed layout and the property is somehow inherited to the description tooltip, I have to check if this is intended. |
Thank you for your reply!
