25 Pages«<1819202122>»
Offline joaobr
#381 Posted : 10 May 2020 15:30:13(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Great!
Offline joaobr
#382 Posted : 16 May 2020 17:42:12(UTC)
joaobr
Brazil
Hi!
Just to confirm: so far setprop can't address Traces both in ZedGraph and X-Y Plot, right?
Offline uni
#383 Posted : 16 May 2020 17:50:10(UTC)
uni
Was thanked: 1163 time(s) in 672 post(s)
Yes, I found out only how to do it. I will explore another way to control component settings. The correct way is to specify the variable name directly in the properties. I think that it will be more intuitive than all other methods.
Russia ☭ forever
Viacheslav N. Mezentsev
on 16/05/2020(UTC)
Offline joaobr
#384 Posted : 16 May 2020 17:53:41(UTC)
joaobr
Brazil
Thank you!
Offline uni
#385 Posted : 17 May 2020 02:54:08(UTC)
uni
Updated.
Changes:
- increased calculation speed;
- green frame restored when region in evaluation.
Russia ☭ forever
on 17/05/2020(UTC)
Offline uni
#386 Posted : 17 May 2020 17:04:30(UTC)
uni
Updated.
Changes:
- setprop() partially fixed.
Russia ☭ forever
on 17/05/2020(UTC),  on 17/05/2020(UTC)
Offline uni
#387 Posted : 20 May 2020 09:02:26(UTC)
uni
Updated.
Changes:
- implicitplot method improved.
Edited by user 20 May 2020 22:54:23(UTC)  | Reason: Not specified
Russia ☭ forever
on 20/05/2020(UTC),  on 21/06/2020(UTC)
Offline ian3125
#388 Posted : 21 June 2020 08:10:43(UTC)
ian3125
Philippines
Can anyone help me with 2D plots. I have several questions.
1. how do I input/show the units on the graph?
2. how do I scale the units/number on the axis. the graph is in N-mm vs N, I want to change it in kN-m vs kN.
3. is there a way to automatically adjust the max and min of values on the axis?
PM Curve.sm (6kb) downloaded 15 time(s).
Offline uni
#389 Posted : 21 June 2020 08:39:47(UTC)
uni
You can do it like this
PM Curve (uni).sm (9kb) downloaded 41 time(s).
Russia ☭ forever
on 21/06/2020(UTC),  on 21/06/2020(UTC)
Offline ian3125
#390 Posted : 21 June 2020 09:29:14(UTC)
ian3125
Philippines
Thanks a lot uni
#391 Posted : 22 June 2020 16:02:40(UTC)
Was thanked: 910 time(s) in 738 post(s)
You can have it more productive: Export/Interpolate
Spline Hermite Interpolation General.sm (72kb) downloaded 30 time(s).
#392 Posted : 22 June 2020 18:15:29(UTC)
You can have it convex polyline style: Export/interpolate.
Spline Hermite Interpolation General Polyline.sm (73kb) downloaded 28 time(s).
Offline MarB
#393 Posted : 09 July 2020 15:18:01(UTC)
MarB
in the past, using cases (or if) to plot a function only in in specified range worked well.
Now there appears an ugly line ending nowhere.
By moving the plot range, the line disappears sometime.
Could this please be fixed? I didn't find a workaround, except of plotting tabled values.
Offline PompelmoTell
#394 Posted : 09 July 2020 16:21:14(UTC)
PompelmoTell
Was thanked: 105 time(s) in 89 post(s)
The problem is found with the X-YPlot plugin and not with the original 2D chart of Smath. At the moment you can use the two tricks as in the picture.SMathStudio_Desktop_25VenrcLu4.png
#395 Posted : 09 July 2020 17:12:38(UTC)
You CAN NOT blank scalar canvas plot X_Y.
Alternately, discretize /tabulate your range of interest
then plot the data in X_Y. The bonus is that on rough
data from source plot "splines" to smooth the discontinuities.
Advanced Bezier interpolation works as well.
X_Y rejects the if/otherwise blanking character "
Offline MarB
#396 Posted : 09 July 2020 18:23:16(UTC)
MarB
Didn't I show, that I CAN!?
I know plotting tabulated values, maybe I didn't write clearly.
#397 Posted : 09 July 2020 19:13:32(UTC)
plot g(x) white ... plot/no plot axes.
Offline uni
#398 Posted : 09 July 2020 22:25:23(UTC)
uni
Yes, when adding a new feature when displaying implicit curves, I had to change the working code. I could not immediately fix the artifacts.
Russia ☭ forever
#399 Posted : 14 July 2020 14:52:39(UTC)
if/else or if/otherwise never did work at least up to SS 6179.
X_Y is essentially designed around data set.
Quite convenient but not as the champion OriginLab.
OriginLab is the software dedicated for Phamacokinetics,
hyper rich in plot styles but strictly from data sets.
IMHO, I see no point to trick/fix what ? nothing, use as is.
These two styles of demo are common as well as the 1/x.
logpts enables intelligible tabulated export and plot.
Utilities logpts Demo.sm (27kb) downloaded 28 time(s).
Offline MarB
#400 Posted : 14 July 2020 21:20:14(UTC)
MarB
Und jetzt?
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
