Originally Posted by: Mathys Hello dear Smath fans,
with v0.99.7251 I cannot open any longer the "Format..." menu with the right mouse button on inserted x-y-Plots. After clicking on it, Smath is freezed.
After minimizing Smath to the task bar with third party tools and reopen this Smath process again from the task bar I am able to edit the open document without issues. But as soon as I try to use "Format..." again on any x-y-plot, the freezing happens againg. So the usual format pop-up window does not appear at all.
Is this the right forum group for this issue? Or is it better to place it elsewhere? E. g. "SMath Studio Forum » SMath Studio » Bugs & Problems"
Thanks and regards In this case try to press [Alt]+[Space] for context menu and move hidden Format window. The component saves the coordinates and position of the settings window. When restoring a window, it may happen that the coordinates are outside the current desktop. |
Thank you Viacheslav, good to remember this for future occuring of this effect. Meanwhile it disappeared, because I re-installed the plugins. However it might be necessary to use:
- not only "Alt-Space" but also
- "Cursor down" and
- "Enter" and
- "Cursor left/right/up/down2
to catch and move this lost format windows back to the visible screen. There are also special third party "Window Hunter" tools, but I am not aware if they can hunt only windows applications or also all kind of pop-up-windows from these applications. Thank you and best Regards Rudolf
is there something wrong, i cant install any plugin. when i install plugin the smath will close by itself
Originally Posted by: zackchen is there something wrong, i cant install any plugin. when i install plugin the smath will close by itself Try this: - Open a file explorer window and in the address bar type %APPDATA% and hit enter
- Find the SMath folder and rename it (f.e. SMath_old)
- Launch SMath Studio and check if the problem is solved
Originally Posted by: Davide Carpi Originally Posted by: zackchen is there something wrong, i cant install any plugin. when i install plugin the smath will close by itself Try this: - Open a file explorer window and in the address bar type %APPDATA% and hit enter
I tried it, but it didn't work. I opened %APPDATA% again,like this picture. I think is some problem about uuid.
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
The interactive "Getting started" guide has been updated. Many thanks for feedback and contributions by Ihor Rokach (Holy Cross Technical University in Kielce, Poland). Changes: - Polish translation - Minor corrections (typos) - Improved consistency of keyboard input instructions - Revised section on substitution function at(), now independent of Maxima (which users might not have installed) - some images now are language-specific (using text regions with embedded images) The version is marked as "beta" because it requires SMath Studio build 7251. You need to install some plug-ins. |
4 users thanked mkraska for this useful post.
on 01/08/2020(UTC), on 01/08/2020(UTC), on 02/08/2020(UTC), on 04/08/2020(UTC)
