2 Pages<12
Online PompelmoTell
#21 Posted : 05 February 2020 15:29:37(UTC)
PompelmoTell
the plugin now works thanks to Andrey Clap . Unfortunately the diagrams are made exclusively in imperial units; this greatly limits the use and, if I understand correctly, the author has not expressed his intention to continue the maintenance Sad.
#22 Posted : 05 February 2020 18:13:40(UTC)
Such a joke ! Like the Congress that has not yet defined pi [3 or 4].
Offline Safak
#23 Posted : 16 September 2022 14:59:03(UTC)
Safak
Turkey
Hi everyone,
I have been using Smath for many years, but this is my first time writing to the forum Good
I have a problem with Structural Beam Analysis plugin. I download the Beam Analysis Input Guide from Extansions Manager and didn't change anything in the Smath file.
I couldn't figure out what is causing this situation. Do you have any idea?
Thanks in advance,
Offline churichuro
#24 Posted : 16 September 2022 16:03:41(UTC)
churichuro
Mexico
Was thanked: 27 time(s) in 22 post(s)
work fine for me, maybe -->
This worksheet requires that the associated Plugin (Structural Beam Analysis
Utility Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath
Studio Extension Manager tool.
Offline Safak
#25 Posted : 16 September 2022 16:24:58(UTC)
Safak
Turkey
Thank you for your reply. The plugin was already enabled.
Offline churichuro
#26 Posted : 16 September 2022 18:20:28(UTC)
churichuro
Mexico
It's like there's a missing data
Offline oli123
#27 Posted : 03 January 2023 20:56:24(UTC)
oli123
United Kingdom
Originally Posted by: Andrey Ivashov Go to Quoted Post
Hello.
Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them.
Several days ago I've got permissions to fix an issue.
Originally Posted by: Eneko Go to Quoted Post
Could somebody help me with that?
Plug-in functionality restored now. Tested ok with all available sample worksheets.
New version of a plug-in available using Extensions Manager.
Hi Andrey,
is this plugin source still not shareable? I wanted to modify some of the plotting for my use, such as showing on plot SI units or no unit at all.
Offline uni
#28 Posted : 04 January 2023 13:10:05(UTC)
uni
You can use dotPeek to decompile c# assembly (BeamAnalysisUtilityFunctions.dll). Based on these sources, you can write your own plugin. It will be difficult, but you will be able to realize your ideas.
Russia ☭ forever
Viacheslav N. Mezentsev
2 Pages<12
