2 Pages12>
Offline Eneko
#1 Posted : 16 January 2020 16:58:36(UTC)
Eneko
Spain
Hi everybody,
I'm trying to use the Structural Beam Analysis plugin, but I've got some problems.
When I open the “Beam Analysis” example I've got the next problem.
The error says "Indice fuera de los limites de la matriz" (Index outside matrix boundaries)
Could somebody help me with that?
Thanks in advance
#2 Posted : 16 January 2020 21:38:24(UTC)
Will be easier to doctor from the document, isn't it ?
Offline Eneko
#3 Posted : 17 January 2020 10:46:25(UTC)
Eneko
Spain
I've got the problema with the example that's why I didn't send the file before.
You can find it attached.
Thanks
Beam Analysis Input Guide.sm (87kb) downloaded 69 time(s).
Offline ElSid
#4 Posted : 17 January 2020 18:14:18(UTC)
ElSid
Do an AppVersion on the file Good
There has been a lot of work under the engine by the developers since this was issued. You'll need to update it and preferably, repost. I don't do a lot of beam calcs, so I have not touched this in a while.
NOTE: Opened fine in 7251
Edited by user 17 January 2020 18:42:00(UTC)  | Reason: Not specified
Offline PompelmoTell
#5 Posted : 17 January 2020 19:56:19(UTC)
PompelmoTell
I have the same problems as Eneko, with 7251 versions of SM
Offline Eneko
#6 Posted : 17 January 2020 21:56:49(UTC)
Eneko
Spain
I've tryed in different ways to fix it but I continue with the same error.
Offline CBG
#7 Posted : 18 January 2020 05:57:33(UTC)
CBG
works perfectly on SS7251
Carlos
Offline ndtma
#8 Posted : 18 January 2020 06:01:12(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
There has been a lot of work under the engine by the developers since this was issued.You'll need to update it and preferably, repost.I don't do a lot of beam calcs, so I have not touched this in a while.
The original file showed Red while opening, but finally opened successfully in SS 7251.
Then saved as with a new name, which opens later without any such hassle.
Offline Eneko
#9 Posted : 21 January 2020 14:12:13(UTC)
Eneko
Spain
Could somebody show me how to solve it please?
Thank you in advance
Offline ndtma
#10 Posted : 21 January 2020 17:48:48(UTC)
ndtma
Sri Lanka
The renamed file is attached, including the PDF. I did not do any changes.
Hope you will be able to open it. Also update relevant plug-ins.
Cheers!.
Beam Analysis Input Guide_TEST.sm (388kb) downloaded 52 time(s).
Beam Analysis Input Guide_TEST.pdf (487kb) downloaded 58 time(s).
#11 Posted : 21 January 2020 18:09:10(UTC)
PompelmoTell
I confirm the problem highlighted by Eneko also on my pc with win7 Pro and SM SM "0.99.7251.32800".
The only dependency reported in the guide is the plugin "Structural Beam Analysis
Utility Functions by Redem Legaspi Jr." that is set up and active.
Offline ndtma
#12 Posted : 21 January 2020 18:13:54(UTC)
ndtma
Sri Lanka
Mine is Win 10 Home Edition. SS version same as yours.
Cheers!
Offline uni
#13 Posted : 21 January 2020 18:43:03(UTC)
uni
Page Beam Analysis Utility Functions exists but I see this plugin for the first time. If anybody find sources I can update them to work state.
Quote:
Analysis of Beam with any number of supports and with any type of loadings.
The worksheet requires that the associated Plugin (Structural Beam Analysis Utililty Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath Studio Extension Manager tool.
The worksheet does the following:
1.) Plots Beam Diagram, Shear Diagram, Moment Diagram, Deflection
2.) Calculates Support Reactions
3.) Calculates Shear, Moment, and Deflection at any given point.
Refer to 'Beam Analysis Input Guide.sm' on how to use the plugin.
redemlegaspi1968@gmail.com
Edited by user 21 January 2020 18:50:57(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 21/01/2020(UTC),  on 21/01/2020(UTC)
Offline zigoreto
#14 Posted : 21 January 2020 19:21:13(UTC)
zigoreto
Spain
Same problem as Eneko and PompelmoTell :___(
Thanks fro helping ndtma and uni!
Offline zigoreto
#15 Posted : 27 January 2020 13:52:07(UTC)
zigoreto
Spain
Hi uni and thank you very much for offering your help.. I'm going to try to find the sources you asked for, mailing Redem Legaspi. Any specific file or extension?
Hugs!
Zigor
Offline uni
#16 Posted : 27 January 2020 14:49:15(UTC)
uni
Redem Legaspi can ask Anrey how to upload sources to svn. After that we'll can maintain his project without author.
As far as I can see, the last update was made by Andrey. Maybe he has sources.
Russia ☭ forever
Offline zigoreto
#17 Posted : 27 January 2020 17:14:01(UTC)
zigoreto
Spain
You're right, uni..
I've already contacted Redem and he suggested me also writing Andrey; Redem can't recover right now plugin sources.
I've mailed Andrey. I'll keep you informed.
Thanks a lot for helping!
Zigor
Offline eswte
#18 Posted : 29 January 2020 18:12:55(UTC)
eswte
Costa Rica
Hi I have the same problem with the Beam Analysis, have you got some answer?
Offline Andrey Ivashov
#19 Posted : 05 February 2020 10:11:36(UTC)
Hello.
Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them.
Several days ago I've got permissions to fix an issue.
Plug-in functionality restored now. Tested ok with all available sample worksheets.
New version of a plug-in available using Extensions Manager.
thanks 3 users thanked Andrey Ivashov for this useful post.
on 05/02/2020(UTC),  on 05/02/2020(UTC),  on 05/02/2020(UTC)
Offline zigoreto
#20 Posted : 05 February 2020 12:35:03(UTC)
zigoreto
Spain
Dear Andrey,
I've just download the plugin and check the SMath sheet.
I've only performed few tests, but it's working perfectly.
Thank you so much for your help and effort. Really.
Best regards!
Zigor
2 Pages12>
