SMath Studio - SMath
Taking everything into consideration, we can state that SMath Studio is a powerful application that lets you create and calculate even complex expressions, with options to plot graphs and solve matrices. The workspace lets anyone quickly accommodate regardless of experience, while the auto-complete feature and rich library of content make sure you learn to love math.
more...
by Mircea Dragomir
Andrey has given us back the joy of Math that we experimented with Mathcad some thirty years ago, until PTC messed it all up. A fantastic achievement! And free! I am beginning to use it intensively to help my engineering students.
more...
by Manuel Vargas
Without a doubt it is one of the best tools for engineering, a good substitute for Mathcad
more...
by Marcel F. Chevalier S.
on 08/11/2019(UTC), on 09/11/2019(UTC), on 13/11/2019(UTC)
Blackout issue Originally Posted by: ElSid
Originally Posted by: ElSid I have the same issue (0.99.7251.32800) with the acoustic file As soon as it was noticed, I gave the cure. Why not suite the original thread ?
Originally Posted by: Jean Giraud Originally Posted by: ElSid Why not suite the original thread? Because it's still a bug that popped up on some of my other sheets. I also posted in the other thread
Originally Posted by: ElSid Because it's still a bug that popped up on some of my other sheets.I also posted in the other thread As long as you can doctor in two clicks.
Andrey, Bug alert. I was updating a snippet in this version and it lost ALL of the information. I don't know if the rest of the data is still in this file RS_User Defined Units.smz (5kb) downloaded 23 time(s).This snippet had an issue in 99.7030 too (Portable)! Could it be the SMZ file format? I saved a version as SM and that appears to be OK. However, another file, not used as a snippet, saved OK in both formats. The regions or areas? Edited by user 22 November 2019 01:56:04(UTC)
| Reason: Added 7030 issue
1 user thanked ElSid for this useful post.
Originally Posted by: ElSid Bug alert.I was updating a snippet in this version and it lost ALL of the information.I don't know if the rest of the data is still in this file
Use your backup, re-save
Originally Posted by: ElSid Andrey, Bug alert. ... Hi. I save as smz a file with an area, and have the same issue. appVersion = "0.99.7251.32800" Best regards. Alvaro.
Joined: 23/07/2013(UTC) Posts: 1,125 Was thanked: 506 time(s) in 337 post(s)
The last two versions (7250-7251) are not working on fully updated Arch Linux with Mono. 7219 is working but it has two glitches which are lowercase greek character related.
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
The interactive "Getting started" guide has been updated to SMath version 7251. Most of the update work was spent on utilizing the new features of the text region - Arial as default font (saves approx. 20-30% of space compared to Courier New) - Usage of embedded math in text regions The new version is marked as "beta". You need to install the latest beta version 7251 and some plug-ins. |
4 users thanked mkraska for this useful post.
on 02/01/2020(UTC), on 03/01/2020(UTC), on 03/01/2020(UTC), on 03/01/2020(UTC)
Martin, The NEW interactive guide is not showing up for me. On my end, it shows you posted this message 20 hrs ago. Did the updated file upload correctly? Thank you for updating the documentation
Originally Posted by: ElSid Martin, The NEW interactive guide is not showing up for me. On my end, it shows you posted this message 20 hrs ago. Did the updated file upload correctly? Thank you for updating the documentation The new version has been downloaded several times, thus it should be accessible. Make sure to - search for it in Extension manager as Example (not as interactive book) - allow for beta versions in the online gallery If that doesn't work, you still can download the file from the extension summary page as linked in my previous post. Then open it in SMath Studio just as any other sm file. Edited by user 03 January 2020 22:22:38(UTC)
Has anyone noticed that the "newer" versions does not underline the space between words? Is this intended? Is there a way for me to change this?
Thanks!
Originally Posted by: RFreund does not underline the space between words Isn't true that you can underline something existing: word, letter, symbol Did you mean underscore between two words ? Do you refer to text, formula ?
Joined: 10/06/2013(UTC) Posts: 50 Was thanked: 6 time(s) in 6 post(s)
Доброго времени суток! При наборе текста по умолчанию если нет пробелов, то этот текст является переменной, но как только появляется хотя бы 1 пробел эта переменная преобразуется в текст. Если к этому тексту применять форматирование (например подчеркивание), то в версии 7030 пробелов не было, а в 7251 есть пробелы (разрывы) в подчеркивании: Probely v podcherkivanii.sm (2kb) downloaded 15 time(s).Спасибо! Еще всплыл один вопрос: сейчас по умолчанию шрифт изменился на Arial. Можно ли это умолчание поменять? Дело в том, что при редактировании старых расчетов, а именно - добавление новых областей, шрифт в них не меняется. В итоге получается так: Edited by user 15 January 2020 16:38:03(UTC)
1 user thanked genf for this useful post.
Sorry for my delayed response. What genf shows is what I'm talking about. I want all text and spaces between underlined like this Not just the text like thisI beleive the first instance is fairly standard for most text editor applications. Also if I change the text to Courier New it works as I expect. If it is Arial (or others) it does not. Thanks again Edited by user 15 January 2020 18:27:31(UTC)
Originally Posted by: RFreund I want all text and spaces between underlined like this Writer region does it piece wise or global.
2 users thanked Jean Giraud for this useful post.
on 16/01/2020(UTC), on 17/01/2020(UTC)
@Jean - Good point. I suppose that is a 'workaround' for now.
Originally Posted by: RFreund @Jean - Good point. I suppose that is a 'workaround' for now. Ну это как вариант, но в 7030 то все нормально было ведь. Как оказалось это проблема в шрифте Arial, с другими такого нет (например Arial Narrow). Как быть со шрифтом в заголовке области? Edited by user 10 March 2020 09:14:37(UTC)
Hello dear Smath fans, with v0.99.7251 I cannot open any longer the "Format..." menu with the right mouse button on inserted x-y-Plots. After clicking on it, Smath is freezed. After minimizing Smath to the task bar with third party tools and reopen this Smath process again from the task bar I am able to edit the open document without issues. But as soon as I try to use "Format..." again on any x-y-plot, the freezing happens againg. So the usual format pop-up window does not appear at all. Is this the right forum group for this issue? Or is it better to place it elsewhere? E. g. "SMath Studio Forum » SMath Studio » Bugs & Problems" Thanks and regards P.S.: After some testing with parallel installation of
- stable version v0.99.7030 and
- beta version v0.997251
and after deleting all plugins and reinstallation of a couple of required plugins the problem of missing "Format..." popup for x-y-plots disappeared. Strange. ---> I will monitor and report any new findings. Edited by user 01 April 2020 14:53:22(UTC)
