Hello to all I solved this differential equation: I wanted to know if the procedure I used is correct… this is the .sm file… vel-imb.sm (26kb) downloaded 15 time(s).Thanks in advance
Originally Posted by: Ale16595 I wanted to know if the procedure I used is correct⦠Maybe it is correct. The solver you use is transmitted Unicode ? not digestible as is. Why not stay Native Smath ODE Solver(s) ? ... as doctored/attached SS 6179 vel-imb Doctored Native Smath ODE solver(s).sm (27kb) downloaded 24 time(s).
