2 Pages12>
Offline CBG
#1 Posted : 21 December 2019 06:50:23(UTC)
CBG
Reviewing the Levenberg Marquardt Method with a Jacobian matrix for finite differences,
solving an example taken from the website:
http://support.ptc.com/h...east_squares_fitting.htm .
Algorithm_Levenberg_M_with_DF_SS7251.sm (211kb) downloaded 42 time(s).
Algorithm_Levenberg_M_with_DF_SS7251.pdf (570kb) downloaded 41 time(s).
Carlos
Edited by user 21 December 2019 07:47:33(UTC)  | Reason: Not specified
thanks 2 users thanked CBG for this useful post.
on 21/12/2019(UTC),  on 27/12/2019(UTC)
Offline mkraska
#2 Posted : 21 December 2019 14:34:27(UTC)
mkraska
Solution using the Maxima package lsquares via the interface functions of the Maxima plugin
fit1.sm (30kb) downloaded 42 time(s).
on 21/12/2019(UTC),  on 21/12/2019(UTC)
#3 Posted : 21 December 2019 19:27:24(UTC)
Thanks: Carlos, Martin.
SS 6179 does not complain but still pedaling in 10 min ???
1. in Mathcad [8 Pro ... 11] type ERR= after Minerr
ERR is undocumented = SSD [discovered by Paul W.]
2. alternate to corr, SSD sometimes meaningless [Viod ratio, Verhulst].
3. Often, the best fit is Conjugate Gradient.
Genfit VoidRatio.sm (66kb) downloaded 27 time(s).
Genfit Verhulst.sm (57kb) downloaded 23 time(s).
Genfit Weibull.sm (55kb) downloaded 26 time(s).
Offline CBG
#4 Posted : 24 December 2019 09:13:34(UTC)
CBG
Thanks, Martin
Hello Jean:
I tried to run the algorithm of Levenberg Marquardt, in the version of SS6179,
but it inevitably fails, giving an incorrect solution.
It seems that the error could be in some operation where a single value vector
is produced. Could you take a look to see if you can doctorate ?.
I post again the version of the algorithm in SS7251 with some minor changes.
Algorithm_Levenberg_M_with_DF_SS6179.sm (514kb) downloaded 25 time(s).
Algorithm_Levenberg_M_with_DF_SS7251_R1.sm (210kb) downloaded 21 time(s).
Carlos
#5 Posted : 26 December 2019 18:11:47(UTC)
Helo Carlos,
I deleted all previous postings of no more interest.
I found no way to iterate LM ? Otherwise, easy to initialize
from the al_nleqsolve as suggested in the last part of the attached.
In Mathcad, LM was found hyper robust to initialize,
but most of the times, better fit are concluded from CG.
The Weibull example is one of the easiest to fit.
Very many aren't so easy to fit from model(s), more reflexive.
Some model functions can't be fitted at all, unless from trial/error.
A great piece of work, to get familiarized in fitting session.
Thanks Carlos ... Jean
Genfit Weibull [LM_Iteretive CG] Copy.sm (437kb) downloaded 20 time(s).
#6 Posted : 26 December 2019 18:46:45(UTC)
... then like this:
refit from observing the bar deviation.
Genfit Weibull [LM,al_nleqsolve Companion].sm (103kb) downloaded 16 time(s).
#7 Posted : 26 December 2019 20:24:39(UTC)
... then like this:
... the fully tutored version.
Genfit Weibull [LM,al_nleqsolve Companion] Copy.sm (105kb) downloaded 28 time(s).
Offline CBG
#8 Posted : 27 December 2019 05:29:57(UTC)
CBG
Hello Jean
Thank you very much.
The question is: Why does the SS7251 version directly obtain the solution,
changing the values correctly of the β variable, while the SS6179 version does not,
and they have to be manually entered as new values of the vector of the assumed initial solution. ?
The algorithm is the same for the 2 versions of SmathStudio, so what is the difference if the
programming and decision definitions are supposed to work the same?
Carlos
#9 Posted : 27 December 2019 06:35:45(UTC)
A most interesting observation !
SS 6179 may have to do with the conditional statement.
SS 6179 is "zero" tolerance. So, it may just navigate then end.
It could be SS 7251 conditional is coded more tolerant
Mathcad style and reaches convergence ? Watson, are you there ?
Cheers Carlos ... later on.
Offline Razonar
#10 Posted : 27 December 2019 09:09:57(UTC)
Razonar
Uruguay
Hello Jean
Carlos
Hola Carlos. Just check the code from the SS6179 version, in the while not(stop) loop, the line with A:=J^T*f is wrong, it must to be A:=J^T*J.
on 27/12/2019(UTC)
#11 Posted : 27 December 2019 21:47:32(UTC)
Thanks Alvaro ... doctored !
Weibull LM [0.1,1] 1 min
Weibull CG [0.1,1] 2.3 sec ... ½ max residual deviation
Carlos, your very original LM [Pharmacokinetics] works faster.
an it be compacted algo style ... tried not to avail ?
Hola ! Avaro, Carlos ... Jean
Genfit Weibull [LM_Iteretive CG].sm (438kb) downloaded 21 time(s).
Genfit [Algo Minimize(L-M)].sm (117kb) downloaded 20 time(s).
Offline CBG
#12 Posted : 28 December 2019 02:37:54(UTC)
CBG
Hola Alvaro.
Muchas gracias por tu corrección.
Cuando copie y pegue directamente el codigo de SS7251 a SS6179 daba el error de
"Ecuacion demasiado larga para visualizarla" con un tiempo de ejecusion de mas de 7 minutos,
por lo que opté por copiar manualmente el codigo, pensando que las declaraciones eran interpretados erroneamente, y
fue cuando copie mal la formula.
Hello Alvaro.
Thank you very much for your correction.
When copying and pasting directly the code from SS7251 to SS6179 it gave the error of
"Equation too long to display" with an execution time of more than 7 minutes,
So I chose to manually copy the code, thinking that the statements were misinterpreted, and
It was when I copied the formula badly.
Muchas gracias tambien a Jean por su apoyo y sus comentarios tan acertados.
Carlos
#13 Posted : 28 December 2019 04:14:29(UTC)
I Understand Carlos ...
Now, for your bed time reading, these two fits level Mathcad GenfitMatrix.
By far, they beat former NBS-125.
Rational fractions have exceptional fitting/interpolation virtues.
Thanks and credit to Jeff who helped me so much ...
About same timing as MCD 11
Jean ... enjoy.
Genfit 0000000 Rational Auto-init ITER Copy.sm (150kb) downloaded 19 time(s).
Offline John Suh
#14 Posted : 09 January 2020 04:47:05(UTC)
John Suh
fit1.sm (30kb) downloaded 42 time(s).my god.. i didn't know this was a thing! i'm really glad a friend led me to this forum. hey can you check out this website? solidpapers.com was where I had one of my geometry homework done and I got a passing grade! can you see if it also works for you? i'm planning to order another paper from them again. tell me what you think!!!
#15 Posted : 09 January 2020 14:29:55(UTC)
Fitting data set is a long discours, much longer in techniques/methods.
The Mathcad/Mathsoft LM is the quick/robust ... bingo/done.
Not the best in very many instances.
Attach your data set in this Forum.
Make sure they are raw data from collection, i.e: not freaked by unknown.
Cheers ... are we going to see you again ?
#16 Posted : 10 January 2020 05:14:39(UTC)
1. al_nleqsolve fits the model through selected equalities.
The data set may be moderately noisy.
2. GenfiMinimize is essentially the Cholesky LS solver.
My collection is not lean [177 documents ...some duplicates].
Genfit linfit HyperRobust [Ge Crystal].sm (82kb) downloaded 19 time(s).
Genfit [Algo Minimize(al_nleqsolve Alco, Thurber)].sm (86kb) downloaded 21 time(s).
Offline CBG
#17 Posted : 14 January 2020 23:42:56(UTC)
CBG
Hello Jean
I know you understand perfectly, and that has been the intention.
The second Levenberg Marquardt algorithm has been passed as a function
in the versions of SS7251 and SS6179, the examples published by Jean in
"Genfit linfit HyperRobust [Ge Crystal] .sm"
and 2 other previous examples have also been solved.
Unfortunately, version SS6179, for unknown reasons
does not solve the first example, and results in the
same starting solution vector, the other examples are solved without problem.
LM2A_as_a_Function_SS7251.sm (151kb) downloaded 17 time(s).
LM2A_as_a_Function_SS6179.sm (145kb) downloaded 18 time(s).
Carlos
thanks 1 user thanked CBG for this useful post.
on 15/01/2020(UTC)
#18 Posted : 15 January 2020 21:39:52(UTC)
Hola ! Carlos.
You don't specify if the SS 7251 solves that example.
Please, don't drop dead at reading.
This example attached, Mathcad [L-M, CG, QN] does not even
return the exact coefficients. I tortured myself on that.
On the other hand as well, many model functions can't be
fitted from being too much reflexive within themselves.
For those non willing fit, al_nleqsolve will generally succeeds.
Mathcad failed as well the ITER Cadarache Cu resistivity.
Was done otherwise via sub methods. At least for ITER,
Mathcad returned: "Too complicated to solve"
u:=(0≤x)*(x≤10) useful constrain the Quick plot.
Thanks for your immense dedication.
Genfit [Algo Minimize(al_nleqsolve Pharmacokinetics) ... AUTOMATED] Copy.sm (105kb) downloaded 14 time(s).
Offline CBG
#19 Posted : 16 January 2020 02:16:40(UTC)
CBG
Hola Jean!
Levenberg Marquardt's second algorithm in SS7251 does solve the example. All data
with a tolerance of 10 ^ -16 can be used, or 4 selected data with a tolerance of
10 ^ -8 can be used, in both cases, the starting vector is [0.5 1 1 1].
LM2A_as_a_Function_SS7251_R1.pdf (799kb) downloaded 17 time(s).
LM2A_as_a_Function_SS7251_R1.sm (206kb) downloaded 20 time(s).
The idea was to run the LM algorithm as a function for SS7251 and SS6179, for which
use your examples.
Jean, I tell you that I take the results you show in your exercises as the exact or correct ones
Thank you
Carlos
on 16/01/2020(UTC)
#20 Posted : 16 January 2020 21:35:31(UTC)
They are all correct, good fit from model.
There are many more techniques to best fit by region(s)
The last example SS 6179 spits the fit very fast vs other
solvable previous examples ... supports tol 0.00000001.
Comfort yourself: model fit needs no more than 6 decimals
or less ... from zillions done.
Thanks Carlos for your doctoring expertise.
Genfit 000000000000 L-M AUTOMATED Carlos 20200115 [Exampless].sm (212kb) downloaded 21 time(s).
Guest (2)
2 Pages12>
