Joined: 28/08/2014(UTC) Posts: 649  Was thanked: 348 time(s) in 226 post(s)
Originally Posted by: veb  Hello! Sometimes you want the calculation to show by which formula the calculations were performed.
With some limitations, you can do that with this.  combo.sm (5kb) downloaded 33 time(s).Best regards. Alvaro.
Joined: 02/02/2016(UTC) Posts: 35   Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: Razonar  With some limitations, you can do that with this.
Thanks. It works and maybe it will be enough. But anyway, adding the ability to fomatted label would be great, then this definitely closed this issue
Joined: 04/07/2015(UTC) Posts: 5,165  Was thanked: 818 time(s) in 650 post(s)
Originally Posted by: veb  Sometimes you want the calculation to show by which formula the calculations were performed. Use for this combo boxlist is not beautiful. Formatted label would be more accurate. But Formatted Label does not display a formalized formula. Is it possible to add such a possibility to the formatted label? And in addition, the ability to remove the frame around the edges of the formatted label? T Formatted Label is superb for official document, meets all demands. Maybe except for ComboBox. I don't even know what ComboBox was invented for. Done SS 6179 ... please report if red in your SS version. The graph is done outside, on the RHS, then slided-in. Cheers ... Jean Image Formated LABEL [Oxyhemoglobin].sm (18kb) downloaded 63 time(s).
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,329   Location: Italy Was thanked: 1173 time(s) in 772 post(s)
PLUGIN UPDATED SMath Studio 0.99.7250 and later- content of strings starting with s: is now rendered as math object;
PLUGIN UPDATED SMath Studio 0.99.7251 and later- Enhanced alignments of embedded MathRegions;
- The menu button is now within the "Controls" group;
Edited by user 04 July 2020 23:22:07(UTC)
Joined: 27/05/2016(UTC) Posts: 29   Location: Little Rock, Arkansas Was thanked: 4 time(s) in 4 post(s)
I've really been getting some good use out of this plugin for pass/fail warnings on calcs, but here's a question. I tried using a check mark and X in an if statement in the label, and it displayed correctly in the if statement but not in the result. This was using the Segoe UI Symbol font. First I'd copied and pasted from Windows Character Map and the output was just the unicode number for that symbol. I went to Settings and changed the font to Segoe UI Symbol to see if that would help but it didn't. Is this something that is possible? Thanks!  |
Jason McCool Robbins Engineering Little Rock, AR, USA |
Thank you Jason, I think that I've missed to implement it in some branch of the code, I'll fix it ASAP. |
About CharMap, you have to experiment several up until you get the appropriate character instead of Unicode. For direct calculations, Smath error message is sufficient. You can't really trace from within program, not even Mathcad 11. Calculations may have passed but so wrong !
Not sure what you are after ?
Originally Posted by: Jason McCool  I've really been getting some good use out of this plugin for pass/fail warnings on calcs, but here's a question. I tried using a check mark and X in an if statement in the label, and it displayed correctly in the if statement but not in the result. This was using the Segoe UI Symbol font. First I'd copied and pasted from Windows Character Map and the output was just the unicode number for that symbol. I went to Settings and changed the font to Segoe UI Symbol to see if that would help but it didn't. Is this something that is possible? Thanks!  Just released a fix, it should works now. |
on 15/10/2020(UTC), on 15/10/2020(UTC)
Works great now - Thanks!  |
