SMath Studio Forum
Samples
Applications for equrep: expression isolation and laplace transform.
Hi. Two Applications for equrep: expression isolation and laplace transform. Must to have a lot of bugs. Sugestions are welcome. equrep.sm (122kb) downloaded 65 time(s). equrep.pdf (216kb) downloaded 66 time(s).Best regards. Alvaro.
on 19/11/2019(UTC), on 19/11/2019(UTC)
Originally Posted by: Razonar Hi. Two Applications for equrep: expression isolation and laplace transform. Must to have a lot of bugs. Suggestions are welcome.
Alvaro, can't help ... I don't understand in what eqrep should help or be useful. Laplace stuff does not come out of blue sky. Laplace of a function puts that function in the Laplace domain. From there, you can inverse wrt to any applicable 'new s domain'. 1-[exp(-t)*cos(3*t)]/2 Jean. Laplace Numerical Algo Style READ 3rd.sm (10kb) downloaded 29 time(s). Inst_TurboGen Signum.sm (87kb) downloaded 21 time(s). Inst_TurboGen Smath.sm (119kb) downloaded 22 time(s). Inst_PID [MCD Model].sm (180kb) downloaded 28 time(s).
Originally Posted by: Jean Giraud I don't understand in what eqrep should help or be useful.
Hi Jean. You use maple in your files, which it's a great plugin, but external to smath. I just use only smath code. Best regards. Alvaro.
Originally Posted by: Razonar Hi Jean. You use maple in your files, which it's a great plugin, but external to smath. I just use only smath code.
I understand Alvaro, Good luck to replace all the maple capabilities. There is lot more than Laplace to make work, IMHO: eqrep will never be exhausted. Further: the tracability of an Smath/maple document is implicit [per say] ... thus will pass QA [Quality Assurance]. Cheers ... Jean.
Solving an ODE by laplace transform. Just only SMath code. laplaceODE.sm (151kb) downloaded 55 time(s). laplaceODE.pdf (227kb) downloaded 45 time(s).Best regards. Alvaro.
on 20/11/2019(UTC), on 20/11/2019(UTC)
1. This document links to a Laplace table to explore. 2. Certify the accuracy of the Numerical Inverse Laplace. Laplace Numerical Algo Style EDU.sm (84kb) downloaded 27 time(s).
on 23/11/2019(UTC), on 23/11/2019(UTC)
SMath Studio Forum
Samples
