2 Pages<12
Offline uni
#21 Posted : 18 July 2018 20:46:46(UTC)
uni
Updated. System.Diagnostics namespace added.
Script.Process.sm (5kb) downloaded 118 time(s).
Code:
@echo off
echo Hello
exit
Edited by user 18 July 2018 20:50:11(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 18/07/2018(UTC)
Offline KhasanMamaev
#22 Posted : 15 August 2018 07:53:00(UTC)
KhasanMamaev
Was thanked: 3 time(s) in 2 post(s)
Вячеслав благодарю за Скрипт регион. Этот инструмент делает возможности СМат Студии практически безграничными. Немного программирую на Python. Я так понимаю, что в Script Region используется
IronPython?
Offline uni
#23 Posted : 15 August 2018 10:32:44(UTC)
uni
Да, используется IronPython.
Russia ☭ forever
Offline uni
#24 Posted : 17 September 2018 06:22:21(UTC)
uni
Updated.
- input placeholder removed;
- terms variable removed;
- SMath.Controls assembly added.
Russia ☭ forever
Offline uni
#25 Posted : 18 September 2018 16:26:21(UTC)
uni
Updated. Version 0.2.x.x.
Changes:
- xml serialization format changed;
- reworked.
Old versions of the plugin will not be able to open files of a new format.
Originally Posted by: uni Go to Quoted Post
You can change font with mouse wheel and Control key when region selected.
Disabled until the better implementation.
Edited by user 18 September 2018 20:56:40(UTC)  | Reason: Not specified
Russia ☭ forever
Offline Farja
#26 Posted : 10 October 2018 23:36:37(UTC)
Farja
Chile
With the last changes in the plugin, this simple script to get the filename of the current worksheet stop working:
Code:
store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
The original question, and the script to get the filename its from this post:
https://en.smath.info/forum/yaf_...ileAccess.aspx#post39408
Thanks for your help!
Offline uni
#27 Posted : 11 October 2018 09:54:40(UTC)
uni
Russia ☭ forever
Offline Farja
#28 Posted : 12 October 2018 18:35:58(UTC)
Farja
Chile
Thanks Uni! That change did the trick
#29 Posted : 14 November 2019 08:04:35(UTC)
KhasanMamaev
I want to show you a video about the operation of the Script Region plugin
thanks 1 user thanked KhasanMamaev for this useful post.
on 14/11/2019(UTC)
Offline wb.c
#30 Posted : 05 March 2021 00:56:16(UTC)
wb.c
Was thanked: 22 time(s) in 19 post(s)
What happened to this plugin? Seems like it had a lot of potential.
Offline uni
#31 Posted : 05 March 2021 07:03:05(UTC)
uni
I don't have time to finalize his code editor. Now it is inconvenient to use it.
Russia ☭ forever
Offline joaobr
#32 Posted : 08 March 2021 14:54:24(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Hi, uni!
I'm wondering if the script region for VB would allow me to access a COM engine.
I'm trying to use Autodesk Robot via SMath thorugh its API.
Is there any chance of success in this endeavour?
A simple example of what I've got:
Imports System
Imports RobotOM
Module Program
Sub Main()
Dim robapp As IRobotApplication
robapp = New RobotApplication
robapp.Project.CalcEngine.Calculate()
robapp.Project.Close()
robapp = Nothing
End Sub
End Module
Offline uni
#33 Posted : 08 March 2021 15:11:50(UTC)
uni
As far as I know, there are theoretically no restrictions of any kind. But practically in the plugin code the list of used libraries is strictly specified. In order to use COM-objects, the text of the program is not enough. It is necessary to make it clear to the linker what this program is composed of. Therefore, it will definitely not work now, since even the import directive is not supported.
I can expand the script format like Jon Skeet did. I didn't find an example, but he suggested splitting the code into two parts: a header and a script. Three dots are used as a separator. The header consists of an import list. This list can be used to partially restore dependencies.
In general, it is possible to modify the plugin to do this kind of thing. But I have my own job and it is difficult for me to make significant changes in the existing code.
Russia ☭ forever
Offline joaobr
#34 Posted : 08 March 2021 21:33:46(UTC)
joaobr
Brazil
Thanks for your reply, uni
I totally understand. I'll probably need to use the API via Excel then.
Offline Camilo
#35 Posted : 16 November 2022 17:30:04(UTC)
Camilo
Chile
Was thanked: 2 time(s) in 1 post(s)
This plugin cant be installed on the latest version of Smath:
thanks 2 users thanked Camilo for this useful post.
on 16/11/2022(UTC),  on 30/11/2022(UTC)
Offline Thiago Pereira
#36 Posted : 30 November 2022 17:46:58(UTC)
Thiago Pereira
Brazil
Same as Camilo. Error to/ or update/ reinstall plugin.
Offline uni
#37 Posted : 02 December 2022 11:06:36(UTC)
uni
The problem appeared, but its cause is not yet clear. I'll let you know when it's resolved.
Russia ☭ forever
Offline Kenny Lemens
#38 Posted : 02 December 2022 19:41:05(UTC)
Kenny Lemens
Was thanked: 58 time(s) in 37 post(s)
Viacheslav,
I was developing an plugin between v1.0 and v0.99 and while my plugin 'worked,' I noticed my region interfered with the graphics (local version, in debug mode), that is the graphics fail to print (and sometimes load) when the region was processed/drawn. I had to reference the version specific *.dlls and that solved my problem. As such, I also noticed that some of the properties/classes changed ever so slightly (not enough to fail a compile, but enough to interfere with operations).
I didn't document this in detail though. I'm just wondering if you have some elements tied to the v0.99- that the v1.00+ no longer implements.
This is an amazing tool; thank you for developing it and I hope you are able to restore its functionality!
-Kenny Lemens, P.E. ᵂᴵ
Similar Topics
Paste text does't works on Script Region (Bugs & Problems)
by oscampo 03/07/2021 01:14:53(UTC)
Script Region video (Extensions)
by KhasanMamaev 14/11/2019 07:58:50(UTC)
2 Pages<12
