2 Pages12>
Offline ndtma
#1 Posted : 08 November 2019 11:08:51(UTC)
ndtma
Sri Lanka
Was thanked: 75 time(s) in 52 post(s)
Thank you Andrey for the Latest Beta 7250.
But, the attached SS File yields an error due to different result of
integration in 7250 compared to result in 7219.
SPI_Calc_Plain.sm (112kb) downloaded 19 time(s).
#2 Posted : 08 November 2019 12:13:29(UTC)
Was thanked: 1152 time(s) in 756 post(s)
Do you have the same settings about integrals' accuracy in both the versions?
2019-11-08 10_11_42-SMath Studio - [SPI_Calc_Plain.sm].png 2019-11-08 10_10_32-SMath Studio - [SPI_Calc_Plain.sm_].png
Offline ndtma
#3 Posted : 08 November 2019 14:20:08(UTC)
ndtma
Sri Lanka
Yes, same settings in both versions.
But the difference is in Eqn 2
Offline Andrey Ivashov
#4 Posted : 08 November 2019 18:15:57(UTC)
Was thanked: 1624 time(s) in 545 post(s)
Thank you very much! It was a real calculation error I've introduced in 7250.
Fixed in 7251 (will be available very soon).
UPDATE: Released here: https://en.smath.com/for...1--08-November-2019.aspx
Best regards, Andrey Ivashov.
Edited by user 08 November 2019 18:28:11(UTC)  | Reason: Not specified
on 08/11/2019(UTC)
Offline ndtma
#5 Posted : 10 November 2019 06:15:32(UTC)
ndtma
Sri Lanka
I deleted my previous post for more corrections.
Still I get errors in SS 7251.
I will come back soon.
Sorry for the inconvenience.
Offline ndtma
#6 Posted : 10 November 2019 09:59:21(UTC)
ndtma
Sri Lanka
Integration results of Mathcad attached (using first 10 elements of X
and Eqns 1, 2 and 3.)
SPI_Calc_Plain.sm (126kb) downloaded 14 time(s).
Rainfal_Data.xlsx (487kb) downloaded 10 time(s).
Edited by user 10 November 2019 18:54:20(UTC)  | Reason: Forgot to attach the rainfall data file (Excel)
#7 Posted : 10 November 2019 17:01:56(UTC)
Was thanked: 791 time(s) in 627 post(s)
What I understand from your previous reports is that
the Simpson integrator is kaput again in latest SS version.
What more is kaput ? SS 6179 does not open your attachment.
In the mean time, can you doctor rkfixed your document ?
NDTMA.sm (55kb) downloaded 12 time(s).
Offline ndtma
#8 Posted : 11 November 2019 08:31:56(UTC)
ndtma
Sri Lanka
Thank you. I will try my best ASAP.
In the mean time following files are attached.
Test_Gamma_7251.sm (36kb) downloaded 13 time(s).
Test_Gamma_7251.pdf (193kb) downloaded 10 time(s).
#9 Posted : 11 November 2019 16:59:00(UTC)
Here is doctored sanity MCD.
Don't forget Smath Gamma(x) is only globally 4 decimals,
immaterial in your CDF integration. If you need to check
the peak location of PDF, we have the Golden ratio algo.
Enjoy ... Jean.
NDTMA Test Gamma.sm (46kb) downloaded 8 time(s).
#10 Posted : 11 November 2019 19:14:35(UTC)
... max PDF located
NDTMA Test Gamma.sm (23kb) downloaded 10 time(s).
Golden Ratio jmG.sm (36kb) downloaded 10 time(s).
Offline ndtma
#11 Posted : 12 November 2019 13:07:16(UTC)
ndtma
Sri Lanka
Sincerely, I was trying to show that results of Gamma Function CDF
in 7251 were not compatible with 7219.
I wish to add that similar working in 7219 reasonably tally with MCD and EXCEL,
while 7251 is not so. I believe that may be the reason why I got errors using
SS ICDF.normal function in SPI calculations (some CDF values>1 ??).
Anyway, I am attaching the following files and images for further examination please.
Many thanks to all for their comments.
Fimal Gamma Results.zip (1,170kb) downloaded 10 time(s).
Edited by user 12 November 2019 16:00:12(UTC)  | Reason: Not specified
Offline Razonar
#12 Posted : 12 November 2019 16:16:46(UTC)
Razonar
Uruguay
Was thanked: 280 time(s) in 173 post(s)
Hi. You can try to implement your own algo's for gamma and int functions.
Test_Gamma_7251.sm (104kb) downloaded 14 time(s).
on 12/11/2019(UTC),  on 12/11/2019(UTC)
Offline ndtma
#13 Posted : 12 November 2019 17:53:09(UTC)
ndtma
Sri Lanka
Hi,Thank you. Your suggestion is highly commendable and accepted. Bravo!
But, very often, as practicing Engineers, we are inclined to use built-in
functions as much as possible in our day to day work in the design office.
The SPI calculation was such an effort I came across.
Edited by user 12 November 2019 17:56:48(UTC)  | Reason: Not specified
#14 Posted : 12 November 2019 18:07:05(UTC)
Sincerely, I was trying to show that results of Gamma Function PDF and CDF
As you say ... hard to doctor this patient.
Your download opened by default on my 6179 carries the bug.
Could it be the vectorize operator is the cause ?
If so: that would be quite a bug !
Test_Gamma_7251 [6179].sm (23kb) downloaded 11 time(s).
Offline ndtma
#15 Posted : 12 November 2019 19:39:00(UTC)
ndtma
Sri Lanka
It worked! Thanks, but how?
Test Gamma [2] 7251 [6179].sm (26kb) downloaded 8 time(s).
Offline Razonar
#16 Posted : 12 November 2019 19:43:07(UTC)
Razonar
Uruguay
Hi Nugegodage. I absolutely agree. Actually, I post for try to find where the bug is.
I include gamma too, because I think that, like happen in matlab and maple, plugins can be written in native smath code, not in c++. Maybe in this case, gamma and other special functions are not the best example for do that, but this is only meanwhile they are in plugins, not in smath native functions.
In my point of view, plugins are good for graphics, some objects (like formatted cells, writer regions), communication with external programs (maple, maxima) and some other things.
Offline ndtma
#17 Posted : 12 November 2019 20:32:37(UTC)
ndtma
Sri Lanka
I have edited part of my original "SPI_Calc_Plain.sm" worksheet, and it
is evident the bug due to the vectorize operator.
Will come back soon with the edited version.
Thank you very much.
Offline ndtma
#18 Posted : 12 November 2019 20:52:43(UTC)
ndtma
Sri Lanka
This confirms Jean's guess about vectorize operator.
TEST-SPI_Calc_Plain.sm (53kb) downloaded 7 time(s).
#19 Posted : 12 November 2019 21:17:55(UTC)
Answer is from observation(sss..)
My work sheet is clean and thus opened/calculated your 7251.
Your 7251 is corrupted and my 6179 executed the vectorize bug.
Mathematica has the expression shadow in context.
Read this: 6179 does not come with ZedGraph, one day some collab
posted a ZedGraph, 6179 did open and now my 6179 has ZedGraph.
SS 6346 had two versions: the official and un-official.
The un-official did lot more than the published version.
Detail about Gamma(x)like erf(x): under the integration operator,
they both need be vectorized. Maybe, the fact that I renamed/recast
it may have the virtue of doctoring. Though your Gamma(x) does
not play apparent role in the integration, it is still there as
a reluctant item to evaluate.
Now, if you recast your Gamma(x) Γ(x) in your original 7251
what happens bug/no_bug ? Like the English say: square the corner.
#20 Posted : 12 November 2019 21:23:46(UTC)
Thanks Alvaro,
Never Give up. Great things take time.
2 Pages12>
