SMath Studio Forum
Bugs & Problems
Different Results of Integration in 7219 & 7250 (Gamma Function)
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Thank you Andrey for the Latest Beta 7250. But, the attached SS File yields an error due to different result of integration in 7250 compared to result in 7219. SPI_Calc_Plain.sm (112kb) downloaded 24 time(s). |
Do you have the same settings about integrals' accuracy in both the versions? |
Yes, same settings in both versions. But the difference is in Eqn 2 |
I deleted my previous post for more corrections. Still I get errors in SS 7251. I will come back soon. Sorry for the inconvenience. |
Integration results of Mathcad attached (using first 10 elements of X and Eqns 1, 2 and 3.) SPI_Calc_Plain.sm (126kb) downloaded 19 time(s). Rainfal_Data.xlsx (487kb) downloaded 15 time(s).Edited by user 10 November 2019 18:54:20(UTC)
| Reason: Forgot to attach the rainfall data file (Excel) |
Originally Posted by: ndtma Integration results of Mathcad attached (using first 10 elements of X and Eqns 1, 2 and 3.)
What I understand from your previous reports is that the Simpson integrator is kaput again in latest SS version. What more is kaput ? SS 6179 does not open your attachment. In the mean time, can you doctor rkfixed your document ? Cheers ... Jean NDTMA.sm (55kb) downloaded 17 time(s).
Originally Posted by: Jean Giraud In the mean time, can you doctor rkfixed your document ? Cheers ... Jean Thank you. I will try my best ASAP. In the mean time following files are attached. Test_Gamma_7251.sm (36kb) downloaded 18 time(s). Test_Gamma_7251.pdf (193kb) downloaded 15 time(s). |
Originally Posted by: ndtma Thank you. I will try my best ASAP. In the mean time following files are attached. Here is doctored sanity MCD. Don't forget Smath Gamma(x) is only globally 4 decimals, immaterial in your CDF integration. If you need to check the peak location of PDF, we have the Golden ratio algo. Enjoy ... Jean. NDTMA Test Gamma.sm (46kb) downloaded 12 time(s).
Sincerely, I was trying to show that results of Gamma Function CDF in 7251 were not compatible with 7219. I wish to add that similar working in 7219 reasonably tally with MCD and EXCEL, while 7251 is not so. I believe that may be the reason why I got errors using SS ICDF.normal function in SPI calculations (some CDF values>1 ??). Anyway, I am attaching the following files and images for further examination please. Many thanks to all for their comments. Fimal Gamma Results.zip (1,170kb) downloaded 14 time(s).Edited by user 12 November 2019 16:00:12(UTC)
Hi. You can try to implement your own algo's for gamma and int functions. Test_Gamma_7251.sm (104kb) downloaded 20 time(s).Best regards. Alvaro.
on 12/11/2019(UTC), on 12/11/2019(UTC)
Hi,Thank you. Your suggestion is highly commendable and accepted. Bravo! But, very often, as practicing Engineers, we are inclined to use built-in functions as much as possible in our day to day work in the design office. The SPI calculation was such an effort I came across. Edited by user 12 November 2019 17:56:48(UTC)
Originally Posted by: ndtma Sincerely, I was trying to show that results of Gamma Function PDF and CDF in 7251 were not compatible with 7219. I wish to add that similar working in 7219 reasonably tally with MCD and EXCEL, while 7251 is not so. I believe that may be the reason why I got errors using SS ICDF.normal function in SPI calculations (some CDF values As you say ... hard to doctor this patient. Your download opened by default on my 6179 carries the bug. Could it be the vectorize operator is the cause ? If so: that would be quite a bug ! Cheers ... Jean Test_Gamma_7251 [6179].sm (23kb) downloaded 16 time(s).
Originally Posted by: Jean Giraud As you say ... hard to doctor this patient. Your download opened by default on my 6179 carries the bug. Could it be the vectorize operator is the cause ? If so: that would be quite a bug ! Cheers ... Jean
It worked! Thanks, but how? Test Gamma [2] 7251 [6179].sm (26kb) downloaded 13 time(s). |
Hi Nugegodage. I absolutely agree. Actually, I post for try to find where the bug is. I include gamma too, because I think that, like happen in matlab and maple, plugins can be written in native smath code, not in c++. Maybe in this case, gamma and other special functions are not the best example for do that, but this is only meanwhile they are in plugins, not in smath native functions. In my point of view, plugins are good for graphics, some objects (like formatted cells, writer regions), communication with external programs (maple, maxima) and some other things. Best regards. Alvaro.
Originally Posted by: Jean Giraud Could it be the vectorize operator is the cause ? I have edited part of my original "SPI_Calc_Plain.sm" worksheet, and it is evident the bug due to the vectorize operator. Will come back soon with the edited version. Thank you very much. |
Originally Posted by: ndtma It worked! Thanks, but how? Answer is from observation(sss..) My work sheet is clean and thus opened/calculated your 7251. Your 7251 is corrupted and my 6179 executed the vectorize bug. Mathematica has the expression shadow in context.Read this: 6179 does not come with ZedGraph, one day some collab posted a ZedGraph, 6179 did open and now my 6179 has ZedGraph. SS 6346 had two versions: the official and un-official. The un-official did lot more than the published version. Detail about Gamma(x)like erf(x): under the integration operator, they both need be vectorized. Maybe, the fact that I renamed/recast it may have the virtue of doctoring. Though your Gamma(x) does not play apparent role in the integration, it is still there as a reluctant item to evaluate. Now, if you recast your Gamma(x) Γ(x) in your original 7251 what happens bug/no_bug ? Like the English say: square the corner. Cheers ... Jean
Originally Posted by: Razonar Hi Nugegodage. I absolutely agree Thanks Alvaro, Never Give up. Great things take time.
SMath Studio Forum
Bugs & Problems
