Can anyone help recover this file? It says that there is no XML start tag open. See attached Thanks in advance! New Beam Design.sm (192kb) downloaded 46 time(s).Edited by moderator 04 October 2019 18:19:12(UTC)
| Reason: added BTS ID
Joined: 23/03/2016(UTC) Posts: 275 Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: RFreund Can anyone help recover this file? It says that there is no XML start tag open. See attached Thanks in advance! New Beam Design.sm (192kb) downloaded 46 time(s). Fixed. New_Beam_Design_fixed_alyles.sm (201kb) downloaded 57 time(s).For anyone curious. I ended up fixing an empty tag for this particular area title to have an explicit start and end tag. I don't know enough about the SMath parser to know why this is a problem. I didn't try deleting it. Problem: Solution Edited by user 03 October 2019 22:13:05(UTC)
2 users thanked alyles for this useful post.
on 04/10/2019(UTC), on 04/10/2019(UTC)
Problem: Solution I had the same problem, how did you find the error? There are so much lines y don't know how to find the error
Originally Posted by: eswte I had the same problem, how did you find the error? There are so much lines y don't know how to find the error If you have an editor that supports syntax highlighting for xml is easier, usually you can collapse blocks of code and you can spot where something is wrong. You can try to check yourself using programs such as notepad++ or visual studio code. |
