SMath Studio Forum
Bugs & Problems
Native Windows 10 Application has no menus
Joined: 01/09/2019(UTC) Posts: 2 Location: Carmelo Peralta
Hello. I installed and tried to use the Windows 10 native application found in the Microsoft Store. It has no menus, nothing happens with secondary mouse click. Ctrl, Alt, Shift key combinations does nothing. Double click zooms in, and I did not found a way to zoom out. Clicking to close the application does not ask to save for changes. There is no save current document command, just save as... Is there a way to make the menus appear in the windows 10 native application? Greetings from Paraguay. Claudio Bogado Pompa.
Claudio, do you mean Smath/Win 10 don't work ? This Forum is dedicated to Smath mostly. Often, collabs doctor other request. Cheers, welcome to Smath Community.
What I tested that worked: Typing variable definitions. Typing text blocks. Evaluating expressions. I see that there is a windows 10 installer to be downloaded from another site. I am using right now a computer that I can not install any software outside the Microsoft Store. I downloaded the android version and it is essentially works the same, having the touch gestures to pan and zoom. I guess the Windows 10 native App is designed to touchscreens only. Edited by user 01 September 2019 18:48:47(UTC)
| Reason: Not specified
SMath Studio Forum
Bugs & Problems
