2 Pages12>
Offline omorr
#1 Posted : 21 August 2019 18:58:40(UTC)
omorr
Serbia
This was mentioned on another thread regarding small numbers. Adding two small numbers will cause an error with a rather confusing message (result is above max. positive allowed number???).
There should not be an error but either zero or 1.5e-115 as a result. It is even mentioned in this post that the last working version was 0.99.6824. I believe that some binary arithmetic fails here.
Edited by user 21 August 2019 19:02:45(UTC)  | Reason: Not specified
Online overlord
#2 Posted : 21 August 2019 19:55:05(UTC)
Turkey
Was thanked: 444 time(s) in 298 post(s)
You are right Radovan, this should be a bug. I have checked the addition on old versions.
0.99.7016 (and older versions) can calculate the mentioned additon, 0.99.7100 and after doesn't.
Let me clarify something, exp(709.783) is still not calculated on 0.99.6824 too.
But somehow the Project Fission.sm calculations can be done with 0.99.6824.
As I said on other thread, there are some serious issues over here.
Offline omorr
#3 Posted : 21 August 2019 20:36:11(UTC)
omorr
Serbia
Originally Posted by: overlord Go to Quoted Post
...I have checked the addition on old versions.
I agree and thank you for checking.
#4 Posted : 21 August 2019 22:18:07(UTC)
Was thanked: 961 time(s) in 789 post(s)
For sure 7109 is freaked, not yet doctored.
#5 Posted : 21 August 2019 22:44:36(UTC)
As it looks, 7109 has been deeply victimized.
Something like the American credit card Capital One [109 000 000 victims]
Quebec taxation ministry [30 000 victims]
Another Quebec bank [9 000 000 victims]
on 22/08/2019(UTC)
Offline omorr
#6 Posted : 22 August 2019 09:57:05(UTC)
omorr
Serbia
This error message is also confusing (Numeric optimization of the region).
Why some array and what index is mentioned here?
Online overlord
#7 Posted : 22 August 2019 11:09:11(UTC)
Turkey
The error message is wrong here. Actually the number is bigger than
maximum value of IEEE 754 double-precision standard (binary64) capability.
This is why we are getting an error. (the error should be overflow, not array or index)
http://en.wikipedia.org/wiki/Do...on_floating-point_format
Which is;
2^1023*(2-2^(-52))=1.79769313486232*10^308
If Smath can be recoded with IEEE 754 Octuple-precision (binary256) maximum value could be;
2^262143*(2−2^(−236))=1.61132571748576047361957211845200501064402387454966951747637125049607182699*10^78913
Edited by user 22 August 2019 11:10:50(UTC)  | Reason: Not specified
thanks 3 users thanked overlord for this useful post.
on 22/08/2019(UTC),  on 22/08/2019(UTC),  on 22/08/2019(UTC)
Online overlord
#8 Posted : 22 August 2019 11:19:18(UTC)
Turkey
What I couldn't understand why Smath is giving the error below?
Maximum value of IEEE754 binary64 can be calculated and shown on its own.
But why do I get an error if maximum (or minimum) value is assigned to a variable?
on 22/08/2019(UTC)
Offline omorr
#9 Posted : 22 August 2019 11:47:12(UTC)
omorr
Serbia
As we mentionded here many times, SMath always had some serious problems with its core symbolic/numeric engine. Therefore different Optimizations introduced to overcome these problems etc. The problems still remained or reappeared here and there. See this mentioned simple example with different Optimizations.
optim.sm (7kb) downloaded 14 time(s).
thanks 2 users thanked omorr for this useful post.
#10 Posted : 22 August 2019 19:16:50(UTC)
1.5*10^309 is above 32 bit floating ^307
SS 6179 replies otherwise "Result above max allowed positive number"
"Index above the bounds of the array" is seemingly Windows message.
The function is the power function Y^X built-in at machine code level.
As it looks: they call the machine code suite "array" associated with
an "index" executing that suite ???
Radovan, your work hard !
#11 Posted : 22 August 2019 23:39:38(UTC)
Answer is in some ways here, attached.
Functions don't exist in computing machinery. They are machine code from Windows,
from the Padé rational fraction [Hart et al.] 4 arithmetic operations[+,-,*,/].
Their rating is 21 digits floating point -3 uncertain floating digits.
Only 15 are conserved [Excel, Mathcad, Smath ...] taking into account error
propagation from projects and by agreed convention.
As it looks/demonstrated attached, Smath replaces digits above 15 by '0'.
That may not be correct in some ways ?
All that stuff 64 floating point is purely useless for PC on the account
of the explained above. It has surely interest for parallel computing
capable of displaying > 15 digits. No interest for Engineering project.
Attached MCD is from XP Pro. 64 bits floating point. It points the > 307.
Most interesting but NOT that many adepts.
On the other hand, it bother my Thiele as they have to be expanded
via maple. Some coefficients are so long that they can't be evaluated.
I'm thus forced to run in MCD for evaluation.
Offline omorr
#12 Posted : 25 August 2019 10:01:12(UTC)
omorr
Serbia
Just to get back to the more problematic thing here. The edge of the big numbers is not so problematic as the edge of the numbers close to zero (IMHO).
The main problem here is with the rather small numbers close to zero. I think that lots of calculations will fail if we deal with the numbers which have practically zero values because of the errors SMath will popup and stop calculations. I think this behavior can not be acceptable.
Unfortunately, no answers yet about this problem
Edited by user 25 August 2019 11:42:33(UTC)  | Reason: Not specified
on 25/08/2019(UTC)
Offline uni
#13 Posted : 25 August 2019 16:32:34(UTC)
uni
Was thanked: 1243 time(s) in 724 post(s)
There is no difference in the presentation of large and small numbers. To represent a large number, you need one long integer ( a/1 ). To represent a small number, you need long integer ( 1/a ). The problem is long integers, i.e. large numbers. It's all about this: С ⊂ Q ⊂ Z, there C - complex numbers, Q - rational numbers, Z - integers. So, if you have any number as symbolic expression this number is complex number represented with real and image parts as rational numbers represented as big integers. I don't know how it works in SMath Studio, but in Tiny.Science all numbers based on long integers. And a small number is a big number x in equation 1/x.
Russia ☭ forever
Viacheslav N. Mezentsev
on 25/08/2019(UTC),  on 26/08/2019(UTC)
#14 Posted : 25 August 2019 16:59:14(UTC)
I have recollection [1990] zero was defined value ≤ 10e-12=0
Today is not so and anything from anything that calculates.
Mathcad 11 [2003] XP Pro ...
1.7976931348623157*10^-15 = 1.7976931348623157*10^-15
1.7976931348623157*10^-16 = 0.000000000000000
Smath result below may mean something but not to me ≤ e-15
e-15 is only few layers of hydrogen atom at top of 1 km tower,
i.e: not measurable.
on 25/08/2019(UTC)
Offline omorr
#15 Posted : 25 August 2019 20:38:22(UTC)
omorr
Serbia
Some more weird things regarding the presentation of numbers and optimization in SMath
I agree with uni that both internal presentations of small and big numbers are equally important but SMath is obviously doing something wrong.
#16 Posted : 25 August 2019 21:39:26(UTC)
Floating point arithmetic floats in uncertainty.
That's why all functions rated 21 decimals are truncated to 15 display.
Cody Junior has a long explanation on that with different machines.
The book in question is ~ 1990 or before.
1.976262583364990/1.7976931348623157=1.09933255294784
Offline omorr
#17 Posted : 26 August 2019 10:39:50(UTC)
omorr
Serbia
Unfortunately, my question still remained unanswered. Is this going to stay this way or is there any chance of changing this somehow in SMath?
#18 Posted : 26 August 2019 11:56:00(UTC)
Was thanked: 1301 time(s) in 857 post(s)
I think we might try to capture the exception and return a "full 0" for such cases. To be inspected since different optimizations works in different ways (nice catches Radovan).
on 26/08/2019(UTC)
Offline omorr
#19 Posted : 26 August 2019 12:16:41(UTC)
omorr
Serbia
Thank you Davide for your answer and the confirmation that there is actually a problem I suppose.
#20 Posted : 26 August 2019 15:23:17(UTC)
Thanks Davide for attending our distress !
The problem appeared in the Fission project SS 7019 few weeks ago.
Project turned red in the Originator document, but fine SS 6179.
Mathematica 4.0 had NaN
Mathcad 11.2a implemented NaN at design time of DAEP [2003]
Maths Overflow [Max above limit].sm (48kb) downloaded 19 time(s).
Project Fission.sm (188kb) downloaded 18 time(s).
Similar Topics
Evaluating Small numbers (Questions)
by Aj 07/07/2013 19:10:16(UTC)
2 Pages12>
