Offline RSHeavylift
#1 Posted : 25 August 2019 16:41:57(UTC)
RSHeavylift
Hi!
I am new to Smath (previously using mathcad) and I was wondering how do I use the search and replace funtion. F8 is not working for me
Also, is there a way I can insert a Autocad Drawing in the Calculation. I used it for sketchs
Thanks!
#2 Posted : 25 August 2019 20:45:15(UTC)
Also, is there a way I can insert a Autocad Drawing in the Calculation. I used it for sketches
1. Capture AutoCad drawing
2. Paste in Paint as an image
3. Select from Paint, paste in Smath work sheet
4. Evaluate the calculations, slide in the Autocad image.
Offline RSHeavylift
#3 Posted : 27 August 2019 13:36:43(UTC)
RSHeavylift
It is not working for me. F8 is not doing anything. Am I missing any plug ins?
given my equation. I would like to add a new set of formulas instead of using the variable Witem to another (E.g. Wcargo)
#4 Posted : 27 August 2019 13:55:00(UTC)
Was thanked: 1323 time(s) in 873 post(s)
Hello RSHeavylift Offline ,
to use F8 renaming you have to be inside a region (when the text cursor is visible).
Originally Posted by: Davide Carpi Go to Quoted Post
In a region, you can use the F8 key an you'll be able to rename all local variables/functions at once.
Globally, you can do it with the Text Region Utilities plugin.
#5 Posted : 27 August 2019 17:24:20(UTC)
You don't have a global system like Davide example or Lambert W(x).
You must change each one as you wish.
#6 Posted : 27 August 2019 20:25:24(UTC)
In that Pitch-Roll-Yaw document, you can try changing:
any of the [x,y,z,t] for whatever,
follow Davide demo in Q:=
try change 't' for 'u'
Presumably the Autocad draws something related to your snippet above.
If so, draw in Autocad, attach the image, preferably single color,
not too big for my small laptop screen.
I will try to combine the rotation of the image.
Rotate Parametric [t, xyz].sm (15kb) downloaded 17 time(s).
Offline uni
#7 Posted : 27 August 2019 23:04:22(UTC)
uni
If you really need this it is possible to made a dxf viewer plugin (based on netDxf). As for dwg we need free .net library for this format.
Edited by user 27 August 2019 23:07:27(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
#8 Posted : 28 August 2019 02:41:13(UTC)
Rather, you mean insert calculations in the drawing.
Up to certain degree of complexity, Smath will render simple sketches.
Change svg:=1 for svg:=0.875 ... observe the plot !
Spline De Casteljau SVG Companion Drum.sm (44kb) downloaded 18 time(s).
#9 Posted : 28 August 2019 05:48:13(UTC)
... gross mistake in the volume [corrected].
Trunc(Number,part) added.
Spline De Casteljau SVG Companion Drum.sm (46kb) downloaded 22 time(s).
Guest (2)
