Offline hakelm
#1 Posted : 12 August 2019 22:52:05(UTC)
hakelm
Integrating the simple functions 1/x, 1/x², 1/x³ upwards from 1 give correct results for low values of the upper limit but with the upper limit in the order of 200 or higher the results are not what I would expect. Please see the attached worksheet.
Is there a problem with the integral function or is there something I haven't grasped?
H
integral.sm (6kb) downloaded 12 time(s).
Edited by user 12 August 2019 22:55:34(UTC)  | Reason: Not specified
Offline Razonar
#2 Posted : 13 August 2019 07:33:32(UTC)
Razonar
Uruguay
Was thanked: 254 time(s) in 155 post(s)
Hi. It's because the integral it's a numerical procedure, and maybe not a very robust one. So, like any numerical method, if it don't work, just use another.
integral.sm (14kb) downloaded 12 time(s).
Offline PompelmoTell
#3 Posted : 13 August 2019 11:04:21(UTC)
PompelmoTell
Was thanked: 71 time(s) in 59 post(s)
Hakelm,
I opened your file and the results were correct. Therefore I believe that the parameter for the accuracy of the integrals in your SMath installation is not correctly set.
Try to change Tools->Options->Calculation->Integral Accuracy
For example, write 1000
However, Alvaro's considerations must be kept in mind
Edited by user 13 August 2019 12:53:24(UTC)  | Reason: Not specified
Offline hakelm
#4 Posted : 13 August 2019 12:50:17(UTC)
hakelm
Many thanks for two very good answers!
Now I know that Smath doesn't know even the simplest of integrals but that approximation accuracy can be improved upon.
Even if I understand my system doesn't (SMathStudioDesktop.0_99_7109.Mono on Ubuntu 16.04).
It can't find the function Rkadapt.
I guess that the Runge-Kutta functions are to be found i some plugin. Where can I find that?
H
Offline uni
#5 Posted : 13 August 2019 14:44:46(UTC)
uni
Was thanked: 878 time(s) in 493 post(s)
ODE Solvers.
Russia ☭ forever
Viacheslav N. Mezentsev
💰 Support me for plugins development: https://money.yandex.ru/to/410013245578758/100
Online Jean Giraud
#6 Posted : 13 August 2019 16:35:06(UTC)
Was thanked: 751 time(s) in 592 post(s)
The Simpson integrator ranges from exact to freak.
In your examples, increase the integral accuracy from
menu, options, calculations, integral accuracy [max 10000]
Wise to sanity Wolfram Alpha cost is 0.00 $
integral.sm (47kb) downloaded 8 time(s).
Offline hakelm
#7 Posted : 14 August 2019 16:19:49(UTC)
hakelm
May I assume that the SMath-integral is made using Simpson's rule and that the integral accuracy [max 10000] is the number of steps taken by Simpson?
H
Online Jean Giraud
#8 Posted : 14 August 2019 17:14:29(UTC)
Quite right: The Smath integrator is Simpson.
Ranged accuracy [50 ... 10000]. Trivial cases are exact.
Two more exact cases are know 1/x [ln(x), b_spline].
On long range of the variate 'x' the Simpson/Romberg kernel
gives a much better result than simple Simpson.
Carlos adaptive algorithm is fool proof all cases.
You want these two proposed ... reply YES/NO.
Offline hakelm
#9 Posted : 14 August 2019 19:53:22(UTC)
hakelm
Yes please
H
Online Jean Giraud
#10 Posted : 15 August 2019 01:07:51(UTC)
As you can see, Romberg has the virtue of reducing the range of integration
in the [0 ... 1 ] domain. In two versions directly associated with the
Smath native Simpson integrator or Simpson algo style, thus integration
accuracy 'n' @ the user command line.
These two documents are like minimalist tool box.
Integrate Compendium_1 Romberg_FD_Adaptive [Carlos].sm (143kb) downloaded 5 time(s).
Integrate Compendium_21 Simpson-Romberg Merit.sm (139kb) downloaded 7 time(s).
