Hi all
I would like to ask about a function in excel. What İf
If you know , this function gives the variables for the desired results.
For example f(x)= y , input y and get x
Is there any similar function at smath?
Originally Posted by: Seç I would like to ask about a function in excel. What Ä°f
If you know , this function gives the variables for the desired results. For example f(x)= y , input y and get x Is there any similar function at smath? f(x)= y , input y and get x ... This is inversing a function Excel "Target value" is more ancient than Excel. In fact, it comes from the co-founders of Excel TKsolver. For single value of 'y' you can use Smath solve(2), solve(4) ... Otherwise, if you want to InverseFunction it comes from Smath/Maple. Visit "Samples" for a huge Smath document that covers most possible ways of doing this most advanced piece of maths. This document is less than 3 weeks old.
... Samples [4 days ago] InverseFunction-Lambert
Thanks for your time. Thats what i am looking for.
Originally Posted by: Seç Hi all I would like to ask about a function in excel. What Ä°f If you know , this function gives the variables for the desired results. For example f(x)= y , input y and get x Is there any similar function at Smath? Get initiated with this minimalist introduction. Many projects aren't so easy, but on same principles. Solve Inverse Symbolic Suite [EDU_Init].sm (17kb) downloaded 18 time(s).
if('condition','true','false' - Returns 'true'-statement if logical 'condition'-statement is true (non-zero), 'false'-statement otherwise. ADVICE: Choose it from the Programming palette The "if" programming tool returns a value depending on Boolean 'condition'. Boolean condition can be formed by using Boolean palette. Here is a simple example, returning numeric or symbolic result. https://smath.com/wiki/i...utoDetectCookieSupport=1
Originally Posted by: alisonparker if('condition','true','false' - Returns 'true'-statement if logical 'condition'-statement is true (non-zero), 'false'-statement otherwise.
OK but your link has nothing to do with the demand, i.e: solving 'x' for given 'y' in f(x) Has been answered/exemplified.
