SMath Studio Forum
Bugs & Problems
[Custom Functions] Linear Interpolation
Joined: 23/07/2013(UTC) Posts: 1,125 Was thanked: 506 time(s) in 337 post(s)
First of all I don't know if this method is supported, it would be very useful if not. So if this is not a feature please forgive me because I considered as a bug. The "InterBilinear" function gives wrong results if matrix is used for x or y value. interpolation.sm (16kb) downloaded 86 time(s).Regards
Originally Posted by: overlord First of all I don't know if this method is supported, it would be very useful if not. So if this is not a feature please forgive me because I considered as a bug. The "InterBilinear" function gives wrong results if matrix is used for x or y value. Mathcad Bicubic can't be reproduced, even "if it could be" would be useless whereas Smath does not have Matrix 3D plot [only 3 cols]. Your metric X,Y directions aren't correct. You can metric like center as well. You can have surface plot, only... rotate the plot at will. interpolation [Oterwise metric X, Y Directions].sm (34kb) downloaded 53 time(s).
Originally Posted by: Jean Giraud You can have it otherwise from the X_Y surface plot. ... you can create the matrix and the X, Y directions at will. Then just interpolate ... Spline linterp has the virtue equivalent quadratic. It would be mistake to cspline. Cheers ... Jean Bilinear SplineInterp [Construct USER].sm (13kb) downloaded 32 time(s).
It is a bug, thank you! 4th and 5th argument type isn't checked, therefore (unintentionally) vector math applies. |
Originally Posted by: overlord First of all I don't know if this method is supported, it would be very useful if not. So if this is not a feature please forgive me because I considered as a bug. The "InterBilinear" function gives wrong results if matrix is used for x or y value. Two things here: 1. The 4th and 5th arguments are presented in reverse order compared to Mathcad 2. The two dimension spline coding is from unknown source ...neither from either Smath [linterp, cinterp, ainterp] ...could be from erroneous quadratic source code. As given in the attached: Spline(x,y,M) assumed = Mathcad Bicubic2D(x,y,M,vx,object) At this point, you can spline/plot/rotate the surface as suggested before Cheers ... Jean Bilinear SplineInterp [Construct USER].sm (25kb) downloaded 45 time(s).
Originally Posted by: Jean Giraud Two things here: InterpBilinear(vx,vy,M,object,vector) ... does not collect"vector wise" InterpBilinear(vx,vy,M,object,valueX) ... correct That is the answer to the "bug", InterpBilinear(vx,vy,M,object,vector)
SMath Studio Forum
Bugs & Problems
