Offline shinavn
#1 Posted : 03 July 2019 11:03:43(UTC)
shinavn
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Shina
Offline omorr
#2 Posted : 03 July 2019 15:51:17(UTC)
omorr
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 312 time(s) in 266 post(s)
Shina
Could you be more specific please. What example are you talking about?
on 03/07/2019(UTC)
#3 Posted : 03 July 2019 17:51:07(UTC)
Was thanked: 739 time(s) in 580 post(s)
Please, share your application.
LM covers a good % of all fits in Mathcad.
Cases LM fails, Conjugate Gradient is the sole rescue.
Many model functions can only be fitted by hand.
#4 Posted : 10 July 2019 16:05:59(UTC)
Shina
You are right About LM, however not so simple.
al_nleqsolve, LM, ConjugateGradient that produce in Smath, all dependent
upon initials and reflexivity of the model +++ the approach technique.
Data reduction is a great approach technique [Kirby, Thermocouples ...]
In Mathcad LM as well as CG, a technique that works well to initialize
wrt many models is to pass manually initials through 2 points.
That was not explored with Carlos LM.
That technique through 2 points did work well in some Smath fit,
but failed in other fits. Maybe you are working hard on that stuff ?
Attached for the interest of this visit.
Genfit Chemist.sm (35kb) downloaded 24 time(s).
Genfit Minimize Rational KHL.sm (46kb) downloaded 17 time(s).
Genfit Pharmacokinetics.sm (42kb) downloaded 17 time(s).
#5 Posted : 11 July 2019 16:38:07(UTC)
... for your delight => try Laser
Genfit Convolution Laser.sm (232kb) downloaded 22 time(s).
