Poll Question : Do you plan to use SMath Viewer
Choice Votes Statistics
  In learning
12
18 %
  For personal usage
24
36 %
  In buziness
28
42 %
  Useless for me
2
3 %
  Total 66 100%
Guests can't vote. Try login or register.
2 Pages<12
Offline CBG
#21 Posted : 13 June 2019 03:45:16(UTC)
CBG
Was thanked: 57 time(s) in 42 post(s)
Originally Posted by: G-Tate Go to Quoted Post
I found a way!
But it takes time depending on how many vectors you use.
I defined the single element indexes and gave them a name.
Hello G-Tate
I think it is better that you use Excel for data in the form of Vector or Matrix,
and then import them from SMathStudio, so that, the changes you make are saved in the Excel sheet
PruebaImport_Cost_English.zip (1,038kb) downloaded 6 time(s).
Carlos
Offline oscampo
#22 Posted : 13 June 2019 19:40:29(UTC)
oscampo
Was thanked: 42 time(s) in 30 post(s)
Ok...but...
I think that the point is that in this way you neither can edit any value in the viewer...
Offline CBG
#23 Posted : 13 June 2019 20:49:47(UTC)
CBG
Hello Oscampo
Originally Posted by: oscampo Go to Quoted Post
Ok...but...
In SmathViewer you can change the values of the variables, but it does not save any value,
that is, it remains the original value that was put in the SmathStudio
worksheet. SmathViewer is not persistent.
The idea of using it together with a spreadsheet (Excel or Libre Office) is in the
case of vectors or matrices with data that must be updated, without the need to
change the source code. For example for unit prices, so you do not have to type them every time.
Since from my point of view, the executable program of SmathViewer will be used
by a person who does not have access to the source code and who probably
does not know how to program, or who do not want to make changes to it. Otherwise,
if you have access to run the program in the source code (SmathStudio), what
sense would you have to use Smath Viewer?
SmathViewer needs to improve some functions, such as handling vectors and matrices, making persistent changes, etc.
Carlos
#24 Posted : 14 June 2019 06:26:12(UTC)
Was thanked: 741 time(s) in 582 post(s)
Ok...but...
The Viewer is a dead gadget.
It would have to be an I/O [Input/Ouput] to update itself
from external and vice versa update the slave receiver.
A closed control loop is a good example of scanning inputs,
process and outputs values to the control device.
Similar Topics
String in SMath Viewer (Questions)
by FeCO 14/03/2019 18:32:14(UTC)
Header / footer values displayed in SMath Viewer (Feature Requests)
by fedeghi 14/11/2018 11:56:54(UTC)
Resize SMath Viewer window (Questions)
by lcesero 10/09/2018 18:19:33(UTC)
Smath Viewer Output Window to display main output results (Feature Requests)
by fedeghi 24/07/2018 19:03:11(UTC)
How to display string element of the matrix in Smath Viewer? (Questions)
by barmin 29/06/2018 14:53:06(UTC)
[include plugin] missing LinqBridge.dll error in SMath Viewer executables (Bugs & Problems)
by resist 24/11/2017 18:07:37(UTC)
Smath Viewer - The choice of data entry (Project discussion)
by veb 13/07/2017 13:57:06(UTC)
Smath Viewer compiling (Questions)
by CBG 07/02/2017 02:48:18(UTC)
[SV-2373][PRO] can't open Smath Viewer files (Bugs & Problems)
by CBG 31/08/2016 18:58:56(UTC)
Smath Viewer EXE file password (Questions)
by CBG 31/08/2016 18:32:50(UTC)
Units filter for SMath Viewer (Feature Requests)
by brenyw 16/08/2016 03:51:45(UTC)
[SMath Viewer PRO] SV vs third-party plug-ins (Functions) (Bugs & Problems)
by CBG 29/07/2016 01:50:07(UTC)
[SMath Viewer PRO] SV vs third-party plug-ins (Regions) (Bugs & Problems)
by CBG 28/07/2016 19:48:55(UTC)
Smath Viewer Full Version issues (Bugs & Problems)
by CBG 05/05/2016 06:10:03(UTC)
SMath Viewer "Display Input Data" (Bugs & Problems)
by overlord 02/05/2016 21:09:02(UTC)
2 Pages<12
