Hello everyone... I have a problem when I try opening the Smath Studio... It doesn't open. The version that I use is 0.99.7030. Can you help me about this problem? Thanks...
Hello Miguel, you can try to go into the %APPDATA% path (digit it in the start menu or in the address bar of any explorer window) and rename the SMath folder into something different (f.e. SMath_backup), then launch the program again... It might be even a firewall/antivirus problem, check them if there is some warning.,, Edited by user 10 June 2019 00:21:49(UTC)
Originally Posted by: miguel sambrano I have a problem when I try opening the Smath Studio... It doesn't open. It takes ~ 1 min for the ribbon to end, then opens.
Originally Posted by: miguel sambrano I have a problem when I try opening the Smath Studio... It doesn't open. The version that I use is 0.99.7030. Can you help me about this problem? Your Smath should work same as mine: 1. Smath in Program Files 2. All Smath documents in a dedicated directory C:\Smath7030 3. Smath icon in the task bar 4. Click the Smath icon ... wait ribbon ends ~ 2 min
I have experienced the same one or two times before. But it was never possible to recreate this problem afterwards. As I know this is a very old issue which is still not catched...
Any suggestions about how to reproduce this issues are very welcome.
Best regards, Andrey Ivashov.
