Offline krugerdude
#1 Posted : 28 May 2019 02:56:17(UTC)
krugerdude
New Zealand
I'm having issues with using variables, I have a bunch of equations that have a single variable (end goal is to plot this) and when I use variable functions/matrices they make the outputs wrong somehow.
I have no issues when setting x to be a single number, but when I set x to a range of numbers the outputs go wrong.
https://imgur.com/a/B4Y8Sod
https://imgur.com/a/Qk3IxY8
Am I just doing it wrong?
Edited by user 28 May 2019 03:02:20(UTC)  | Reason: Fixing screen shots
#2 Posted : 28 May 2019 03:49:02(UTC)
Please: attach the Smath work sheet to see what you may be missing.
Offline krugerdude
#3 Posted : 28 May 2019 04:37:14(UTC)
krugerdude
New Zealand
Smath Data Ranges.sm (695kb) downloaded 21 time(s).
Here is the smath file, the important parts are at the bottom.
Offline PompelmoTell
#4 Posted : 28 May 2019 11:09:27(UTC)
PompelmoTell
you have to use the vectorize function
on 28/05/2019(UTC)
#5 Posted : 28 May 2019 15:33:46(UTC)
...added at the end of your document.
Smath Data Ranges.sm (701kb) downloaded 7 time(s).
Offline krugerdude
#6 Posted : 29 May 2019 05:26:56(UTC)
krugerdude
New Zealand
Thanks for your help, the vectors did the trick (although I don't understand why they have to be vectors).
Here is the end result,
#7 Posted : 29 May 2019 11:41:53(UTC)
PompelmoTell
Obviously it's not a trick.
That way you ask to perform the evaluation element by element contained in the vector.
In the wrong way you used, perform the evaluation in a matrix sense (following the rules on matrix operations) because x1 is a matrix (vector).
Offline uni
#8 Posted : 29 May 2019 15:52:57(UTC)
uni
Another form. The arrow is a vector summation.
Russia ☭ forever
Viacheslav N. Mezentsev
