Offline Basile
#1 Posted : 19 May 2019 02:02:12(UTC)
Basile
Was thanked: 8 time(s) in 7 post(s)
I need to draw phasors (lines-vectors) for AC circuit analysis.
- Line from origin to a point.
- Line from a point to another
The magnitude and the angle or Real and Imaginary parts are known.
Is there any related example?
Thank you,
Basile
#2 Posted : 19 May 2019 16:00:57(UTC)
Brute force quick
Offline Basile
#3 Posted : 20 May 2019 07:05:14(UTC)
Basile
Thank you Jean.
Any way to use different colour for some segments?
Put an arrow or a circle at the end?
Have a text to identify each segment?
Basile
Offline uni
#4 Posted : 20 May 2019 08:25:58(UTC)
uni
You can use X-Y Plot Region for this.
XYPlot. Draw shapes.sm (20kb) downloaded 683 time(s).
XYPlot. Draw shapes.pdf (93kb) downloaded 521 time(s).
Edited by user 20 May 2019 08:31:43(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
#5 Posted : 20 May 2019 15:24:12(UTC)
Thank you Jean.
Basile
Hello Basile,
You should be able to build your circuit with the attached.
Make something, attach and we will add text if you can't.
Circle_rkfixed Arrow.sm (28kb) downloaded 27 time(s).
2D Util Bar Arrow Model.sm (23kb) downloaded 20 time(s).
Circle_rkfixed Clock.sm (24kb) downloaded 18 time(s).
#6 Posted : 22 May 2019 16:52:49(UTC)
Thank you Jean.
Basile
Hello, Basile
On that one you can do a bit more.
Too much may be too much, isn't ?
Maths Polygon.sm (18kb) downloaded 29 time(s).
Offline Basile
#7 Posted : 23 May 2019 18:22:45(UTC)
Basile
Hello Jean and Uni,
Why the Lv is not defined?
I express the matrices as function.
And then the vectors evaluate!
What are the red squares to the right?
It looks that this approach of drawing vectors is a begging.
I shall work on it.
Thank you,
Basile Page2-error.sm (13kb) downloaded 11 time(s).
#8 Posted : 24 May 2019 02:32:28(UTC)
Red square in the scroll bar points at the errors in the document.
More elegant arrows proposed.
Page2-error.sm (9kb) downloaded 23 time(s).
on 26/05/2019(UTC)
Offline Basile
#9 Posted : 24 May 2019 21:09:24(UTC)
Basile
Hi Jean,
The arrows fail when the length of the vector changes.
I have tried as a percentage of length but does not look nice.
Scaling the vectors to always be one but will loose real valuesSMath-1.PNG.
Any good idea?
Is there a way to auto-scale the 2D plot or X-Y plot?
One of the vectors is out of the visual plane.
Thanks,
Basile
Offline uni
#10 Posted : 24 May 2019 21:19:13(UTC)
uni
As I said before:
ndtma wrote:
How about a simple arrow?
uni wrote:
I do not know how to do it better. The arrow should look good in different scales and in its own size.
Edited by user 24 May 2019 21:38:23(UTC)  | Reason: Not specified
Russia ☭ forever
#11 Posted : 24 May 2019 23:35:33(UTC)
Any good idea?
None of the quick plot or X_Y plot can be made X, Y directions scalable
similar to Mathcad 11 ... to me: useless.
From an original X_Y plot creation, stretch by handles respect aspect ratio.
If you modify the X, Y directions [max/min], apply close enough HL, HW ratio.
Page2-error (1).sm (12kb) downloaded 13 time(s).
thanks 2 users thanked Jean Giraud for this useful post.
on 25/05/2019(UTC),  on 25/05/2019(UTC)
Offline Ber7
#12 Posted : 25 May 2019 04:44:11(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Another kind of arrow.
Arrow.sm (6kb) downloaded 20 time(s).
thanks 3 users thanked Ber7 for this useful post.
on 25/05/2019(UTC),  on 25/05/2019(UTC),  on 25/05/2019(UTC)
Offline ndtma
#13 Posted : 26 May 2019 03:24:37(UTC)
ndtma
Sri Lanka
Was thanked: 124 time(s) in 82 post(s)
With both arrow heads, based on Jean's method.
Thank you Jean.
Both Arrows.sm (31kb) downloaded 22 time(s).
Edited by user 26 May 2019 03:58:44(UTC)  | Reason: Not specified
Offline Basile
#14 Posted : 26 May 2019 06:52:40(UTC)
Basile
Why I am getting errors when load your file?
The latest Stable: SMath Studio 0.99.7030 (01 April 2019)
At the end I am able to open the file.
I do the same with two arrows 2π apart, but yours is more elegant.
Basile
Edited by user 28 May 2019 04:26:15(UTC)  | Reason: Not specified
