Offline Britt1
#1 Posted : 24 April 2019 22:31:07(UTC)
Britt1
I have a long formula, it will not fit on one line in a standard sheet. I can't see what I am typing, and can't tell if the formula is correct. What do I need to do to see it? If I put a return in the formula, to continue it on the next line, it still does not work.
#2 Posted : 25 April 2019 05:26:13(UTC)
Get used to attach the Smath work sheet. Only patient can be doctored.
Offline CBG
#3 Posted : 25 April 2019 06:03:53(UTC)
CBG
Hello:
See this: https://en.smath.com/for...into-multiple-lines.aspx ,
and this: https://en.smath.com/for...9--14-February-2018.aspx
Carlos
thanks 1 user thanked CBG for this useful post.
on 25/04/2019(UTC)
#4 Posted : 25 April 2019 14:53:47(UTC)
There are surely ways to simplify/split/compact/collect a formula from foreign source
or from invented construction as understood from your typing.
Examine Hypersurface.
The other long expansion arrive from symbolic expansion [eq(t) from maple invlaplace]
For that one, you can recompose by separating NumDen.
Isolate Num, evaluate the pieces, substitute ... etc.
Recompose the all lot in shorter expression.
The longest expansion I have encountered was 23 pages wide.
There are several ways to skin the cat.
Does it help ?
NumDen.sm (18kb) downloaded 28 time(s).
Contour_8 Hypersurface.sm (1,192kb) downloaded 25 time(s).
#5 Posted : 25 April 2019 17:02:17(UTC)
Have you got the same ? easy to sanity check.
