Offline AndreasH
#1 Posted : 25 April 2019 10:35:25(UTC)
AndreasH
Norway
test.sm (8kb) downloaded 14 time(s).
Dear all. I am trying to solve an equation, eq. See attached .sm file. The equation does not have the variable directly, but via other definitions. I can't make this work. Anyone out there able to help quickly?
-Andreas-
#2 Posted : 25 April 2019 12:28:57(UTC)
Hello Andreas,
there are several issues in your worksheet.
  • The shear stress must be Tau(F) or Tau - at your choice - both in definition and in Von Mises equation;
  • Once you fix it you can see that units of Tau are wrong, it's a force while should be a stress - F/(b*L) I guess;
  • Then you should handle the unit of F; use eq(F) to define the Von Mises yeld criterion and set the unit in the first argument of solve, like eq(F*'kN) or eq(F*'N);
  • Finally give a range to solve, otherwise the default of the program you are running it is used;
test - r1.sm (12kb) downloaded 21 time(s).
Edited by user 25 April 2019 12:33:03(UTC)  | Reason: Not specified
on 25/04/2019(UTC)
Offline AndreasH
#3 Posted : 25 April 2019 14:23:38(UTC)
AndreasH
Norway
Thank you Davide.
Sloppy mistake on my part on the shear stress definition Tau. By the way, can the solve-function return with a unit number or does it have to return a unitless answer?
I can easily fix it of course by writing F:=solve(eq(F*'kN),F,0,1000)*'kN
-Andreas-
#4 Posted : 25 April 2019 15:03:45(UTC)
Originally Posted by: AndreasH Go to Quoted Post
Thank you Davide.
-Andreas-
Yes I forget it, that's the way to set the output units (solve as for now can't handle automatically input/output units of unknowns). Good
Edited by user 25 April 2019 15:07:36(UTC)  | Reason: Not specified
Similar Topics
units and user functions issue (Bugs & Problems)
by Davide Carpi 09/07/2012 12:04:08(UTC)
IsString() and user functions (Bugs & Problems)
by Davide Carpi 08/07/2012 03:49:08(UTC)
