2 Pages12>
Offline Britt1
#1 Posted : 23 April 2019 22:14:53(UTC)
Britt1
I just inserted a table region into my sheet, but I can't figure out how to change the number of rows or columns, or how to type in it. I select the boxes and a popup that I don't know what to do with pops up.
#2 Posted : 24 April 2019 00:36:03(UTC)
Was thanked: 751 time(s) in 592 post(s)
Table Region Carlos.sm (13kb) downloaded 37 time(s).
Offline Britt1
#3 Posted : 24 April 2019 01:14:04(UTC)
Britt1
I typed exactly what is in the Table Region Carlos.sm and then added the table below with the Insert Table command, and still it does not work.
Don't know why the picture of the smath file is so big.
Edited by user 24 April 2019 01:19:20(UTC)  | Reason: Not specified
#4 Posted : 24 April 2019 04:58:10(UTC)
Once you have inserted the Table from the insert menu,
in that 3 x 3 chess board: type Table in the place holder.
Print Screen, paste in Paint, Select, paste in a tool
that will save as *.PNG [I use WinGrab for over 20 years]
Offline Britt1
#5 Posted : 24 April 2019 16:04:34(UTC)
Britt1
I defined the temp in degrees F, but it put it in degrees K
Offline Britt1
#6 Posted : 24 April 2019 18:40:21(UTC)
Britt1
What I want to do is produce a table similar to the image I attached: DFU TABLE.png Also, What does the first definition do for the table? In the example it says
Time:= 5 day
Flow := 0.005 ft3/min
Temp := 20F
#7 Posted : 24 April 2019 18:55:59(UTC)
Smath is an advanced CAS. Maybe purchase a tool to list the barn population.
What about Excel, Word ... ?
WinGrab is freeware perpetual for all Windows versions
In 3 clicks for decent image in the Forum:
attach in the Forum
Offline CBG
#8 Posted : 24 April 2019 22:57:57(UTC)
CBG
Was thanked: 60 time(s) in 44 post(s)
Hello
This is a part of your table
Table Region Carlos_R1.sm (29kb) downloaded 21 time(s).
Carlos
Offline Britt1
#9 Posted : 10 May 2019 16:14:44(UTC)
Britt1
After you produce the table in SMath, are the numbers in the table usable in a calculation? If not, then there is no point, and it is better to just copy and paste from Excel.
#10 Posted : 10 May 2019 16:36:58(UTC)
Obviously, you can use any element from Smath data Table or from matrix result,
just address the element as needed ... no limit.
#11 Posted : 10 May 2019 20:01:55(UTC)
... address new value by element
You can add/delete cols/rows, value the cols/rows added.
Offline CBG
#12 Posted : 11 May 2019 01:05:03(UTC)
CBG
Of course, look at the operation fixture 1.2 by fixture 1.4, which results in 4. within the same table.
Carlos
Offline Britt1
#13 Posted : 14 May 2019 21:43:20(UTC)
Britt1
#14 Posted : 14 May 2019 22:32:46(UTC)
Why does my table say 1 deg F and not 30 ?
Please: attach the document so helpers won't have to redo.
Offline Britt1
#15 Posted : 14 May 2019 22:37:21(UTC)
Britt1
test.sm (19kb) downloaded 6 time(s).
#16 Posted : 14 May 2019 22:38:41(UTC)
Was thanked: 1123 time(s) in 733 post(s)
Seems to me that simply you are not using the Temp variable in your Table matrix.
Offline Britt1
#17 Posted : 14 May 2019 22:44:24(UTC)
Britt1
then, it goes completely crazy and puts in an arbitrary value of 137.79
test.sm (19kb) downloaded 4 time(s).
Offline CBG
#18 Posted : 14 May 2019 22:52:24(UTC)
CBG
Here is the correction. It was still necessary to define your own unit of
degrees farenheit to prevent Smath Studio from interpreting it as Kelvin degrees.
On the other hand in the table was missing include the variable Temperature
(temp) divided by the units (° F)
test _Britt1.sm (20kb) downloaded 11 time(s).
Carlos
thanks 1 user thanked CBG for this useful post.
on 14/05/2019(UTC)
#19 Posted : 14 May 2019 22:57:31(UTC)
I'd like it was completely arbitrary, I would have created some sort of artificial intelligence Biggrin
Jokes aside, it is probably the value in the base unit (Kelvin).
I'm sorry but I'm from mobile right now, I can't check it deeply nor provide some example, I hope some of our skilled users can help you more here.
Edit: thank you Carlos
Edited by user 14 May 2019 22:59:02(UTC)  | Reason: Not specified
Offline Britt1
#20 Posted : 15 May 2019 17:09:11(UTC)
Britt1
Can you make a table in one SMath file, and have a calculation in another SMath file refer to the table in a calculation?
2 Pages12>
