SMath Studio Forum
Questions
How manipulate a t vector from simulation datas
Joined: 16/04/2018(UTC) Posts: 3 Location: Ibagué Was thanked: 5 time(s) in 1 post(s)
Hello everyone. I took this archive from example section and I have a question. How i can take the t vector or position vectors from simulation datas for manipulated this values later. Thanks for your help ApprStr.sm (20kb) downloaded 10 time(s). ApprStr.sm (20kb) downloaded 13 time(s).
Originally Posted by: LHMP I took this archive from example section and I have a question. How i can take the t vector or position vectors from simulation datas for manipulated this values later. Sorry Collab: I understand noting in your Smath work sheet. Except for the fact that the mechanism animates. Jean ApprStr [SlopeIntercept].sm (32kb) downloaded 18 time(s).
Hi. For your particulary method of defining path, you need to evaluate f4 for t=tStart for get the first row of path. Further, for the second t=tStart+1*DeltaPhi you get a two rows path. For the last, you can use this: Hope that this is what you want. Best regards. Alvaro.
Originally Posted by: Razonar Hi. For your particulary method of defining path, you need to evaluate f4 for t=tStart for get the first row of path. Further, for the second t=tStart+1*DeltaPhi you get a two rows path. For the last, you can use this: Hope that this is what you want. Best regards. Alvaro. Hello Alvaro. Thanks for you help. I'm a rookie in Smath Studio. Regards Edited by moderator 19 April 2019 14:56:33(UTC)
| Reason: marked as solved
SMath Studio Forum
Questions
