1. This type of spline is for high Technical/Scientific works. 2. It roams around points, governed by the vector of knots. 3. Not easy to manipulate: trial/error for best fit. 4. Most likely it will crash Smath ... save a working copy. 5. Supports indirectly integration [via Smath ainterp typical]. 6. Supports infinitesimal derivative ... at this point: you may adjust the vector of knots from visual inspection of the derivative. Jean Spline0 Quadratic Lagrange Knots.sm (39kb) downloaded 30 time(s).
