Hi, I'am not able to use the assume function. Currently Maxima 5.42.2 is used. I would appreciate any ideas Thanks, Lorenz
Originally Posted by: LorenzAl I'am not able to use the assume function. There are 17 ODEsolve in Smath that will do.
Thanks, Lorenz
Can't reproduce. You might want to use symbolic evaluation for the assume call. |
Also, can work with complexes ... MaxODE.2.sm (18kb) downloaded 18 time(s).Best regards. Alvaro. Edited by user 05 April 2019 10:14:40(UTC)
| Reason: Not specified
Hi Everybody, thanks a lot.....I forgot to evaluate symbolically the assume command.... Edited by moderator 05 April 2019 13:56:43(UTC)
| Reason: marked as solved
