Offline mytam
#1 Posted : 28 March 2019 07:43:16(UTC)
mytam
When creating a new matrix, it would be faster, and more natural to type ctrl+m 2,3 <return>
rather than use both row and column fields
For me personally, the default for columns would best be 1, that is what I use more often than anything else.
I also find filling matrices slow and difficult. It would be much easier to comma delimit data in columns, and semi-colon delimit rows. This would make it easy to fill either across or down. When reaching the end of a row/column, it would wrap to the next (regardless of "," or ";" )
The problem with tab is that it is with keys 1,2,3 + tab is it's a left hand cack handed stretch to the tab key that gets capslock every time, for me. - so I have to do it slowly.
Using comma is left-right-left-right and flows smoothly. (This is the same reason that // is my favourite comment character regardless of language - it flows whereas eg. shift+# never does)
Edited by moderator 25 April 2019 12:40:13(UTC)  | Reason: Not specified
Offline Razonar
#2 Posted : 28 March 2019 10:22:06(UTC)
Razonar
Uruguay
Hi mytam. Isn't very natural, but with this you only need one click.
1) Write ma( into a math area. Then the parenthesis close, and you see ma(_)
2) Write the matrix elements file to column. For example, for a 2x3 matrix, you get: ma(11,12,13,21,22,23)
3) Write the number of files and columns. You get now ma(11,12,13,21,22,23,2,3)
4) Finally, click after "ma" and complete typing a "t". Then mat(11,12,13,21,22,23,2,3) is showing as what it is: a 2x3 matrix.
Or as image, more explicit:
on 28/03/2019(UTC)
#3 Posted : 28 March 2019 16:23:52(UTC)
No short way to fill a matrix ! by hand.
Toke me ½ day to fill 767*2 HadCRU Global Warming data.
The suggested approach is best as you can see side by side
what you fill-in from the source data image.
Offline Andrey Ivashov
#4 Posted : 01 April 2019 01:30:03(UTC)
It is possible with newest release (build 7030). Arguments separator symbol allows you to move focus from rows to columns box now.
Hope this will help you.
#5 Posted : 01 April 2019 03:20:04(UTC)
What more convenient and logic than SS 6179 can be invented ?
fill the first top left -> cursor fill next -> ...
as the last column is filled: drops down next row left
... and so on
negative number: twice cursor ->-> move next.
From the matrix tool box, easy to insert a missing row.
Creating a matrix is a delightful part of a project.
Creating matrix from f(x), f(x,y) is even simpler.
Offline crun
#6 Posted : 25 August 2020 09:48:48(UTC)
crun
I also find matrix entry painful.
Thanks Andrey for implementing, that makes it easier. (tried to edit the Keyboardshortcuts wiki, but can't)
I agree. I think that I expect the r,c values chosen to persist next time ^M is chosen.
I agree.
Currently, if you make a 1x1 matrix then comma fills it down as you describe. i.e.
<ctrl>+M 1,1 4,5,6
makes
4
5
6
I think it needs:
  • ; creates new column (as you describe)
  • <ctrl>+<arrow key> move in the matrix that direction for editing.(currently hard to go up/dn the grid)
  • a shortcut that makes a 1x1 matrix.
e.g. a dedicated shortcut
<ctrl>+;
or
add a new button to matrix dialog to make a 1x1, which has the hotkey m , so pressing
<ctrl>+MM
will make an empty 1x1 ready for filling using , ;
I would also note that entering powers of 10 is also a major pain in matrices, as it is often more than doubling the number of keystrokes.
see: Fast-way-to-enter-powers-of-10
Edited by user 25 August 2020 12:45:02(UTC)  | Reason: Not specified
#7 Posted : 25 August 2020 16:08:28(UTC)
Same style as Mathcad/Mathsoft. No complain in 15 years Collaboratory.
OriginLab matrix is even more painful for reasons.
If you fill a matrix from foreign source, better address elements wise.
Much less risk of typos, than filling by hand.
#8 Posted : 25 August 2020 22:03:03(UTC)
Visit the last Samples attachment, few minutes ago.
Similar Topics
Speed matrix creation and filling with comma (Feature Requests)
by crun 04/05/2018 10:11:04(UTC)
