16 Pages«<1213141516>
Offline Razonar
#261 Posted : 13 March 2019 07:34:13(UTC)
Razonar
Uruguay
Hi. Can the Maxima plugin beheavior could be changed to agree with SMath (and Mathcad) diff operator, when the variable is defined?:
MaximaDiff.sm (7kb) downloaded 36 time(s).
Thanks in advance for your answer.
Offline mkraska
#262 Posted : 13 March 2019 12:04:29(UTC)
mkraska
This would require access to the unevaluated (non-preprocessed) verbatim expression from within the plugin. I don't know if that is currently possible. Same problem applies for definite integrals for numeric evaluation. I could take over numeric quadrature as well if I had access to the unevaluated expression.
Perhaps our other developers have a quick anwer?
Offline Razonar
#263 Posted : 13 March 2019 13:01:44(UTC)
Razonar
Uruguay
Hi Martin. Clean() seems to have this kind of access.
Offline mkraska
#264 Posted : 13 March 2019 15:54:01(UTC)
mkraska
Clear() is defined in the Special functions plugin, which is closed source and probably isn't restricted to the third party plugin API.
The Maxima plugin has already survived several API changes, sometimes Andrey made adjustments even to third party plugins immediately, sometimes major re-work is required and update delays result from that. Unfortunately, I probably will only get up and running again with Visual Studio in summer. There is quite a todo list for the maxima plugin.
Maxima has it's own mechanism for suppressing evaluation/simplification, the so called "noun" property (inactive expression). I filed support for this in the plugin as request SS-3478
Edited by user 13 March 2019 15:55:34(UTC)  | Reason: Not specified
Offline Razonar
#265 Posted : 13 March 2019 17:08:19(UTC)
Razonar
Uruguay
Hi Martin. I see the request SS-3478. But I guess that this isn't related with the noun Maxima's property (x::uneval in maple, and Hold[] in Mathematica. Actually I ask some time ago something like this related with derivatives of cool prop package).
I guess that defining
Code:
bool IPluginLowLevelEvaluation.ExpressionEvaluation(Term root, Term[][] args, ref Store context, ref Term[] result)
where the difference with normal call is ref Store context, and then
Code:
termVar = SMath.Math.Computation.Preprocessing(termVar, ref context);
you can handle the case where an argument is defined, catching the variable name, and trying to determine if it is defined or not.
Actually I paste both of them from Maxima plugin source code. (But the second is commented).
on 13/03/2019(UTC)
#266 Posted : 14 March 2019 05:47:19(UTC)
That's interesting, Alvaro.
My understanding is that the underlying equations are IAPWS, to be tracable.
As implemented in Smath just a cluster fuck. OK, I don't need, using WASP
from Katmar. Under the hood, those functions are monkey business. I say that
because I coded those animals from personal transmission from Bernhard S.
I coded in VB. ALL OK, coded nearly all in Mathcad OK.
About your point of getting the derivative in Smath: not possible.
Not possible unless CoolProp re-coded from A ...Z.
In Smath CoolProp, you just get the interpolated value.
Most probably, those properties are respective data sets, interpolated.
IAPWS are a soup of polynomials. Correctly implemented, you will have
them on plot and derivatives.
I believe this package is the one from Valery at the time of his
web Mathcad calculator.
If interested, can check if still on my MCD 11.
I have most of IAPWS in Smath otherwise approximated, hyper accurate !
Cheers Alvaro ... Jean
PS: WASP from Katmar is not freeware but you have unlimited sessions
of 3 minutes [originally it was 10 minutes].
Offline Razonar
#267 Posted : 15 March 2019 08:32:48(UTC)
Razonar
Uruguay
Hi. There are some issue here:
maxima_laplace.sm (6kb) downloaded 34 time(s).
on 15/03/2019(UTC)
Offline mkraska
#268 Posted : 15 March 2019 12:40:13(UTC)
mkraska
The problem seems to be the pre-mature execution of at() on SMath side. You see that if you switch off the Custom Functions plugin, then the answer is correctly displayed. Thus it isn't a translation issue. It would be desirable to keep the unevaluated response at least if optimization is set to "none".
I need to see if the Maxima plugin can do anything about it or even is the culprit.
Thank you for pointing this out. Filed as SS-4597.
on 15/03/2019(UTC)
Offline Razonar
#269 Posted : 15 March 2019 13:20:07(UTC)
Razonar
Uruguay
Hi Martin. Thanks. Here, exp instead e^ seems to avoid this issue.
Implementation of the Laplace method solving a system of odes with Maxima laplace and ilt transforms, and it's comparative with numerical solution.
Laplace_Maxima.sm (56kb) downloaded 38 time(s).
Laplace_Maxima.pdf (129kb) downloaded 37 time(s).
Edited by user 15 March 2019 14:02:26(UTC)  | Reason: Mistake in sm version.
on 15/03/2019(UTC)
Offline Razonar
#270 Posted : 15 March 2019 15:45:21(UTC)
Razonar
Uruguay
Same as before, but with a system without a close form for the inverse laplace.
Laplace_Maxima2.sm (57kb) downloaded 37 time(s).
Laplace_Maxima2.pdf (161kb) downloaded 32 time(s).
#271 Posted : 15 March 2019 15:49:57(UTC)
Here, exp(x) instead e^ seems to avoid this issue.
As I mentioned this to Reg few days ago, then spot checked in Smath.
No difference was observed on the 15 D results. In Mathcad, yes e^
is less accurate than exp(x) that runs the Win built-in 21 D of which
the kernel retains 17 D and displays 15 by convention.
In other words, Maxima does not recognize e^ as the scalar exp(x).
Offline mkraska
#272 Posted : 15 March 2019 17:16:25(UTC)
mkraska
Confirmed. Thank you, filed as SS-4598
#273 Posted : 15 March 2019 17:19:34(UTC)
Remember Alvaro, we had some exchange on that Mathsoft Collaboratory.
ODE_Laplace Read First.sm (28kb) downloaded 36 time(s).
ODE_Laplace 1rst [Type 1].sm (25kb) downloaded 35 time(s).
ODE_Laplace 1rst [Type 2].sm (23kb) downloaded 33 time(s).
ODE_Laplace 2nd [Type 3].sm (34kb) downloaded 31 time(s).
Created SS 5346 ... OK SS 6179
Offline Razonar
#274 Posted : 15 March 2019 21:46:12(UTC)
Razonar
Uruguay
Hi Jean.
I remember that.
#275 Posted : 17 March 2019 00:22:37(UTC)
Hi Jean.
I remember that.
Try that one with the forcing q(t):= t^0.5 and q(t):= ln(t)
ln(t) expands in term of Ei(,) exponential integral.
How is Maxima will react ?
ODE_Laplace 2nd [Type 3 Dirac Integral].sm (28kb) downloaded 31 time(s).
Offline Razonar
#276 Posted : 17 March 2019 02:35:25(UTC)
Razonar
Uruguay
Hi Jean. Maxima can't find a close symbolic solution, only find the laplace transform. But this example shows how powerful is the Oscar' routine for inverting numerically laplace transforms. RKFixed and RKAdapt fails and, as you point, only the uni specialized solver dn_GearsBDF seems to solve the equation.
Laplace_Maxima6.pdf (95kb) downloaded 40 time(s).
Laplace_Maxima6.sm (65kb) downloaded 38 time(s).
Edited by user 17 March 2019 02:37:38(UTC)  | Reason: Not specified
Offline Razonar
#277 Posted : 17 March 2019 05:49:28(UTC)
Razonar
Uruguay
Hi. This is my attemp to solve a linear equation with polynomial coefficients by laplace method with Maxima. Even don't works, give a solution very close to the numerical RK solver, but I can't see what I'm doing wrong. Any help is welcomed.
Laplace_Maxima5.sm (100kb) downloaded 44 time(s).
#278 Posted : 18 March 2019 21:41:27(UTC)
Can't help Alvaro.
I don't have Maxima. Just posted last minute Oscar InvLaplace.
Don't forget Frobenius for some of those kind variable coefficients.
Works fine Smath, with coefficients helper solve.
Buenos dias Amigo !
Offline netsonicyxf
#279 Posted : 24 March 2020 16:48:21(UTC)
netsonicyxf
I have a portable version of Smath 0.99.7251. The Maxima is under D:\Program Files\Math Tools\SMath Studio\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.7100.23756\
I put the above path into insert->settings, but it show "Cannot find maxima.bat"
Offline mkraska
#280 Posted : 24 March 2020 16:52:54(UTC)
mkraska
Did you install Maxima? If not, follow the link in my signature and see the instructions for installing and configuring Maxima. The plugin just provides the interface.
Guest (2)
Similar Topics
Error implementing ToolboxGroup for the maxima plugin (Questions)
by fakemoses 31/07/2023 20:09:47(UTC)
Maxima Plugin Feedback Survey: Share Your Ideas and Report Bugs (Feature Requests)
by fakemoses 16/06/2023 13:27:33(UTC)
MAXIMA PLUGIN expand (Questions)
by Angel695 21/05/2023 10:43:40(UTC)
Solve Function Stuck (46/47) with Maxima Plugin (Questions)
by Albedo 30/08/2022 05:24:23(UTC)
[Maxima Plugin] Text exportation issue (Questions)
by SteelCat 11/01/2022 12:47:31(UTC)
Maxima Plugin problem (Bugs & Problems)
by FT_PENG 23/12/2021 23:49:19(UTC)
Text characters not passing correctly to Maxima plugin (Bugs & Problems)
by gurro 15/08/2021 00:14:03(UTC)
[Maxima Plugin] is a custom Maxima function call-able in SMath (Questions)
by 007.000 22/05/2018 13:06:49(UTC)
[Maxima Plugin] least common multiple (Questions)
by 007.000 22/05/2018 12:13:20(UTC)
news for Maxima Plugin (Questions)
by oscampo 27/01/2016 18:39:35(UTC)
Maxima plugin error (Bugs & Problems)
by olik 30/11/2015 10:17:28(UTC)
