14 Pages«<121314
Offline Razonar
#261 Posted : 13 March 2019 07:34:13(UTC)
Razonar
Uruguay
Was thanked: 161 time(s) in 101 post(s)
Hi. Can the Maxima plugin beheavior could be changed to agree with SMath (and Mathcad) diff operator, when the variable is defined?:
MaximaDiff.sm (7kb) downloaded 6 time(s).
Thanks in advance for your answer.
Offline mkraska
#262 Posted : 13 March 2019 12:04:29(UTC)
mkraska
Was thanked: 789 time(s) in 504 post(s)
This would require access to the unevaluated (non-preprocessed) verbatim expression from within the plugin. I don't know if that is currently possible. Same problem applies for definite integrals for numeric evaluation. I could take over numeric quadrature as well if I had access to the unevaluated expression.
Perhaps our other developers have a quick anwer?
Offline Razonar
#263 Posted : 13 March 2019 13:01:44(UTC)
Razonar
Uruguay
Hi Martin. Clean() seems to have this kind of access.
Offline mkraska
#264 Posted : 13 March 2019 15:54:01(UTC)
mkraska
Clear() is defined in the Special functions plugin, which is closed source and probably isn't restricted to the third party plugin API.
The Maxima plugin has already survived several API changes, sometimes Andrey made adjustments even to third party plugins immediately, sometimes major re-work is required and update delays result from that. Unfortunately, I probably will only get up and running again with Visual Studio in summer. There is quite a todo list for the maxima plugin.
Maxima has it's own mechanism for suppressing evaluation/simplification, the so called "noun" property (inactive expression). I filed support for this in the plugin as request SS-3478
Edited by user 13 March 2019 15:55:34(UTC)  | Reason: Not specified
Offline Razonar
#265 Posted : 13 March 2019 17:08:19(UTC)
Razonar
Uruguay
Hi Martin. I see the request SS-3478. But I guess that this isn't related with the noun Maxima's property (x::uneval in maple, and Hold[] in Mathematica. Actually I ask some time ago something like this related with derivatives of cool prop package).
I guess that defining
Code:
bool IPluginLowLevelEvaluation.ExpressionEvaluation(Term root, Term[][] args, ref Store context, ref Term[] result)
where the difference with normal call is ref Store context, and then
Code:
termVar = SMath.Math.Computation.Preprocessing(termVar, ref context);
you can handle the case where an argument is defined, catching the variable name, and trying to determine if it is defined or not.
Actually I paste both of them from Maxima plugin source code. (But the second is commented).
on 13/03/2019(UTC)
#266 Posted : 14 March 2019 05:47:19(UTC)
Was thanked: 676 time(s) in 528 post(s)
That's interesting, Alvaro.
My understanding is that the underlying equations are IAPWS, to be tracable.
As implemented in Smath just a cluster fuck. OK, I don't need, using WASP
from Katmar. Under the hood, those functions are monkey business. I say that
because I coded those animals from personal transmission from Bernhard S.
I coded in VB. ALL OK, coded nearly all in Mathcad OK.
About your point of getting the derivative in Smath: not possible.
Not possible unless CoolProp re-coded from A ...Z.
In Smath CoolProp, you just get the interpolated value.
Most probably, those properties are respective data sets, interpolated.
IAPWS are a soup of polynomials. Correctly implemented, you will have
them on plot and derivatives.
I believe this package is the one from Valery at the time of his
web Mathcad calculator.
If interested, can check if still on my MCD 11.
I have most of IAPWS in Smath otherwise approximated, hyper accurate !
Cheers Alvaro ... Jean
PS: WASP from Katmar is not freeware but you have unlimited sessions
of 3 minutes [originally it was 10 minutes].
Offline Razonar
#267 Posted : 15 March 2019 08:32:48(UTC)
Razonar
Uruguay
Hi. There are some issue here:
maxima_laplace.sm (6kb) downloaded 8 time(s).
on 15/03/2019(UTC)
Offline mkraska
#268 Posted : 15 March 2019 12:40:13(UTC)
mkraska
The problem seems to be the pre-mature execution of at() on SMath side. You see that if you switch off the Custom Functions plugin, then the answer is correctly displayed. Thus it isn't a translation issue. It would be desirable to keep the unevaluated response at least if optimization is set to "none".
I need to see if the Maxima plugin can do anything about it or even is the culprit.
Thank you for pointing this out. Filed as SS-4597.
on 15/03/2019(UTC)
Offline Razonar
#269 Posted : 15 March 2019 13:20:07(UTC)
Razonar
Uruguay
Hi Martin. Thanks. Here, exp instead e^ seems to avoid this issue.
Implementation of the Laplace method solving a system of odes with Maxima laplace and ilt transforms, and it's comparative with numerical solution.
Laplace_Maxima.sm (56kb) downloaded 7 time(s).
Laplace_Maxima.pdf (129kb) downloaded 11 time(s).
Edited by user 15 March 2019 14:02:26(UTC)  | Reason: Mistake in sm version.
on 15/03/2019(UTC)
Offline Razonar
#270 Posted : 15 March 2019 15:45:21(UTC)
Razonar
Uruguay
Same as before, but with a system without a close form for the inverse laplace.
Laplace_Maxima2.sm (57kb) downloaded 8 time(s).
Laplace_Maxima2.pdf (161kb) downloaded 8 time(s).
#271 Posted : 15 March 2019 15:49:57(UTC)
Here, exp(x) instead e^ seems to avoid this issue.
As I mentioned this to Reg few days ago, then spot checked in Smath.
No difference was observed on the 15 D results. In Mathcad, yes e^
is less accurate than exp(x) that runs the Win built-in 21 D of which
the kernel retains 17 D and displays 15 by convention.
In other words, Maxima does not recognize e^ as the scalar exp(x).
Offline mkraska
#272 Posted : 15 March 2019 17:16:25(UTC)
mkraska
Confirmed. Thank you, filed as SS-4598
#273 Posted : 15 March 2019 17:19:34(UTC)
Remember Alvaro, we had some exchange on that Mathsoft Collaboratory.
ODE_Laplace Read First.sm (28kb) downloaded 11 time(s).
ODE_Laplace 1rst [Type 1].sm (25kb) downloaded 10 time(s).
ODE_Laplace 1rst [Type 2].sm (23kb) downloaded 9 time(s).
ODE_Laplace 2nd [Type 3].sm (34kb) downloaded 9 time(s).
Created SS 5346 ... OK SS 6179
Offline Razonar
#274 Posted : 15 March 2019 21:46:12(UTC)
Razonar
Uruguay
Hi Jean.
I remember that.
#275 Posted : 17 March 2019 00:22:37(UTC)
Hi Jean.
I remember that.
Try that one with the forcing q(t):= t^0.5 and q(t):= ln(t)
ln(t) expands in term of Ei(,) exponential integral.
How is Maxima will react ?
ODE_Laplace 2nd [Type 3 Dirac Integral].sm (28kb) downloaded 6 time(s).
Offline Razonar
#276 Posted : 17 March 2019 02:35:25(UTC)
Razonar
Uruguay
Hi Jean. Maxima can't find a close symbolic solution, only find the laplace transform. But this example shows how powerful is the Oscar' routine for inverting numerically laplace transforms. RKFixed and RKAdapt fails and, as you point, only the uni specialized solver dn_GearsBDF seems to solve the equation.
Laplace_Maxima6.pdf (95kb) downloaded 11 time(s).
Laplace_Maxima6.sm (65kb) downloaded 7 time(s).
Edited by user 17 March 2019 02:37:38(UTC)  | Reason: Not specified
Offline Razonar
#277 Posted : 17 March 2019 05:49:28(UTC)
Razonar
Uruguay
Hi. This is my attemp to solve a linear equation with polynomial coefficients by laplace method with Maxima. Even don't works, give a solution very close to the numerical RK solver, but I can't see what I'm doing wrong. Any help is welcomed.
Laplace_Maxima5.sm (100kb) downloaded 13 time(s).
#278 Posted : 18 March 2019 21:41:27(UTC)
Can't help Alvaro.
I don't have Maxima. Just posted last minute Oscar InvLaplace.
Don't forget Frobenius for some of those kind variable coefficients.
Works fine Smath, with coefficients helper solve.
Buenos dias Amigo !
Similar Topics
[Maxima Plugin] is a custom Maxima function call-able in SMath (Questions)
by 007.000 22/05/2018 13:06:49(UTC)
[Maxima Plugin] least common multiple (Questions)
by 007.000 22/05/2018 12:13:20(UTC)
news for Maxima Plugin (Questions)
by oscampo 27/01/2016 18:39:35(UTC)
Maxima plugin error (Bugs & Problems)
by olik 30/11/2015 10:17:28(UTC)
14 Pages«<121314
