13 Pages«<10111213>
Offline omorr
#221 Posted : 29 October 2016 21:29:16(UTC)
omorr
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 296 time(s) in 254 post(s)
That's not a bug Radovan:
=>...For the free finding solutions, IC must be either 0 or 1
[1 to releive from "divide by zero"]<= ... {previous message}
Maybe you are not up to date vs Davide ?
I was using SMath 0.98.6128 an NonlinerSolver 1.1.6099.14159
Ra
Offline omorr
#222 Posted : 16 May 2017 19:20:27(UTC)
omorr
Serbia
Originally Posted by: Davide Carpi Go to Quoted Post
Thank you guys, these examples are very useful to fix the bugs in this plugin Good
I'm working to a new version of the code, almost totally refactored.
Looking at your examples seems there are several things to fix in my preprocessor; with some tweak, it is able to solve it.
now I just have to find some consistant way to make it working always Crazy
Davide, any progress about this plugin and its new version?
#223 Posted : 16 May 2017 21:00:19(UTC)
Was thanked: 1087 time(s) in 713 post(s)
Hello Radovan! Good
More or less, I'm trying to make it working on the numerical functions (those containing if/else, etc...), requires some more refactoring, I'll see if I can focus on this plugin in the coming weeks...
on 16/05/2017(UTC)
#224 Posted : 17 May 2017 05:32:46(UTC)
Was thanked: 663 time(s) in 515 post(s)
Maybe, I don't understand much in there ?
Page1 Unknown Solve.sm (31kb) downloaded 36 time(s).
Offline omorr
#225 Posted : 17 May 2017 16:11:59(UTC)
omorr
Serbia
Helo Jean,
You should define f(x) not f(u). See the file, please. Was that your question?
Page1%20Unknown%20Solve-2-corr.sm (35kb) downloaded 32 time(s).
#226 Posted : 19 May 2017 14:55:47(UTC)
Hello Radovan,
Example in context works fine for me. Integrator is now "scalar" 6179.
It enables the Fourier Quantum double integral, though awfully slow.
For N =31, CoC takes > 2hrs [Win 7 1.6 GHz]. ∫(x) comes from Maple.
Integral Curve Nuance.sm (27kb) downloaded 34 time(s).
Offline Alex M.
#227 Posted : 13 April 2018 19:13:37(UTC)
Alex M.
Was thanked: 118 time(s) in 91 post(s)
Hello SMath Community, need some help with findroot() function.
I wrote a formula (biaxial bending in a column) to calculate unknown input loads based on known response. A key to practical use of the formula is to solve for unknown response based on known input loads (backwards of what formula does). When using findroot() for this purpose i run into error:
FidRoot-CustomFormulaSolution.sm (538kb) downloaded 21 time(s).
What am i doing wrong?
Thanks!
#228 Posted : 13 April 2018 19:36:36(UTC)
FindRoot, as well as other solvers of NS plugin, is not friend of eval, if/else or in general anything that requires a strict numerical evalution to be performed... that's a thing I'm working on (long overdue, I know...)
on 13/04/2018(UTC),  on 15/04/2018(UTC)
Offline mkraska
#229 Posted : 12 December 2018 02:14:58(UTC)
mkraska
Was thanked: 787 time(s) in 503 post(s)
I don't know when these changes happened but my current observation of Findroot's behaviour seems to be different from earlier versions:
  • Just evaluate: displays result vector and executes embedded assignment
  • Assign and evaluate in the same region: Error (symbolic evaluation reveals that the expression isn't executed but just stored as if it was inside line())
  • Assign and evaluate in separate regions: displays result vector and executes embedded assignment upon display.
  • Assign wrapped in eval() and evaluate in the same region: displays result vector and executes embedded assignment (here, eval() seems to be a friend of FindRoot())
In the sheet below I tried to demonstrate how to solve a system of equations using FindRoot() as alternative to Solve(). However, I am not sure how to explain the behaviour to the students. Should we generally avoid assignment with integrated evaluation for the time being?
2018-12-12 00_06_28-SMath Studio - [Kerbformzahl Lochstab Biegung FKM.sm_].png
Kerbformzahl Lochstab Biegung FKM.sm (701kb) downloaded 13 time(s).
on 12/12/2018(UTC),  on 12/12/2018(UTC)
#230 Posted : 12 December 2018 03:27:22(UTC)
Yes, they should be avoided. There are several known issues while using implicit assignments, I plan to remove them when I'll have the possibility to commit a major update to this plugin.
Moreover now SMath Studio supports multiple assignments by matrices on LHS, therefore it shouldn't be a big loss.
Offline mkraska
#231 Posted : 12 December 2018 03:41:25(UTC)
mkraska
Perhaps I wasn't clear enough. My example doesn't show any problem with embedded/implicit assignment (at least nothing obvious). What I mean is if you write an assignment with := and in the same region ask for display by = . This one seems to be a problem. Maybe, the two features are related, I don't know.
If you drop integrated/implicit assignment, perhaps would be a good idea to return a set of boolean equations which can be used with at(), just like with Solve(). Then you can easily operate with multiple solutions without having to clear inbetween.
#232 Posted : 10 February 2019 17:22:32(UTC)
Be my guest if you want to solve it
A similar problem problem kept the Mathsoft Collaboratory [mostly Jean]
busy for a while, solving for 22 variables. That was possible finally
from Given/Find with infinitely many trial/error constraints.
Given/Find Mathcad 8 Pro solves for 250
Given/Find Mathcad 11 solves for 400 but not of that nature
Given/Find MCD 11 solves for 399 in for loop as the next call
benefits of the previous estimates. That was done solving a DE
of variable coefficients as functions [something like Frobenius]
The Mathsoft 22 variables surely does not exist anymore in my old box
as it was "secret" about what is was. Maybe the Originator said 'thaks'
but not sure as commonly Done-Gone !
Yet, I don't completely understand the problem and its generation.
Cheers Radovan ... Jean
on 12/02/2019(UTC)
#233 Posted : 10 February 2019 19:29:08(UTC)
Assuredly not a profitable guest !
I don't understand much in there.
Primer38-doomed.sm (40kb) downloaded 12 time(s).
Primer38-doomed_1.sm (45kb) downloaded 8 time(s).
on 12/02/2019(UTC)
Offline omorr
#234 Posted : 10 February 2019 19:45:22(UTC)
omorr
Serbia
Thank you Jeaan for your efforts, but I think we do not understand each other. This is not a fitting problem but finding roots of nonlinear system of equations
The solution was found in Mathcad - this post - and some other software but never in SMath
Offline Razonar
#235 Posted : 10 February 2019 23:59:18(UTC)
Razonar
Uruguay
Was thanked: 156 time(s) in 99 post(s)
Here is the same problem solved in Mathcad
Hi. Can you show the guess values for x and y? And k before Find too. I get a very different k value. Remember that for numerical procedures, guess values are part of the solution, not of the problem.
Thanks in advance.
Offline omorr
#236 Posted : 11 February 2019 11:43:53(UTC)
omorr
Serbia
Thanks in advance.
Thank you Alvaro for your interest in these problems. Here is the file once more.
Primer38-doomed1.sm (32kb) downloaded 14 time(s).
This is a system of nonlinear algebraic equations. If one takes a look at the calculation here it is obvious that any gradient algorithm for solving this system will fail. Therefore, some non-gradient method might solve this (direct solving or some minimization procedure). There are some functions in the NonlinearSolvers plugin, but unfortunately, there is no update of them for a long time and many of them do not work anymore. All of these years I mentioned that we need here some well tested and robust library incorporated in SMath regarding these problems. There are no other plugins which will address these problems (AFAIK) and I am not sure that will ever be any.
Edited by user 11 February 2019 20:19:19(UTC)  | Reason: Not specified
on 11/02/2019(UTC)
#237 Posted : 11 February 2019 22:16:54(UTC)
1. You seem not happy of the result by plugging [x, y] from the other software.
Did you enter enough decimals ? or that software is short of more ?
2. The Smath FindRoots is not robust in there but it can reproduce results
from your source software with more decimals that you collected.
3. Presumably the software is Matlab ?
4. In short: for a fixed Phi, you are attempting to solve pairwise [x,y]
as you scan over 'z'. Isn't true that any pairwise [x,y] will find a valid
solution or closely ? Stated otherwise: the unique non trivial pair [x,y]
is extremely sensitive to initials. That reminds me the Mathcad rootScanner
that I designed for some extremely sensitive initials. But that one tool
is only for one variable.
Primer38-doomed1[Solve paiWise].sm (11kb) downloaded 6 time(s).
#238 Posted : 11 February 2019 22:54:05(UTC)
Did you enterenough decimals ?
on 12/02/2019(UTC)
Offline omorr
#239 Posted : 11 February 2019 23:53:56(UTC)
omorr
Serbia
Hello Jean,
The solution is from Mathcad (Given/Find)
With an increased number of decimals.
#240 Posted : 12 February 2019 04:45:36(UTC)
Hello Jean,
That was my guess, no shame borrowing the hammer as needed.
γRK(T,x):=eval(program) ... > 4 times faster.
13 Pages«<10111213>
