Originally Posted by: tomtit Hello Uni, The plugin is broken again since Smath v.6962 (I'm sure only with ..62 at the end). I've spent half of an hour and located the issue. It is a tiny piece of a big worksheet. Best regards mapledoesntworksince6962.sm (22kb) downloaded 40 time(s). There aren't maple() funtions involved here, therefore can't be a maple tools issue. You can fix it in this way: |
Thanks Davide, But I wrote the f_poly(v) few years ago and there were no troubles till 6965b. It's strange that even minor update requires to review very old (considered reliable) worksheets. f_poly() is pure numerical function and contains tons of evals . How is it possible to corrupt posterior symbolic calculations? Edited by user 06 February 2019 19:15:58(UTC)
| Reason: Not specified
Originally Posted by: tomtit But I wrote the f_poly(v) few years ago and there were no troubles till 6965b. It's strange that even minor update requires to review very old (considered reliable) worksheets. f_poly() is pure numerical function and contains tons of evals . How is it possible to corrupt posterior symbolic calculations? I haven't checked if there are differenes in p content between the versions but I see that in the problem is involved cases(...); if you move the eval fomr the p definition to the "if" condition of cases you have the script working again... Originally Posted by: Andrey Ivashov Support for evaluation plug-ins improved. I can't check it right now but this is probably the change that makes the difference (SS 0.99.6970). |
Hi. Just a very small issue with subscripts: Best regards. Alvaro.
Originally Posted by: Razonar Hi. Just a very small issue with subscripts:
Yellow is OK, a one element vector.
Hello Uni, Recently I found another problem in symbolic calculations that probably related to maple plugin. Let see the example in attachment. This is simple example of constructing of system of equations for circuit of 3-rd order. I need 2*3+2 equations some of them define frequency response, some define of the position of minimums/maximums or the transfer function. The problem happens with taking derivatives. Smath can't calculate them without involving maple plugin. Try disabled equation for H1(n,k,b,w). But using maple(simplify()) it does it right. After this step H1(n,k,b,w) became useless. Any symbolic expression that uses it returns "empty". But if I use copy-pasted output of the H1(n,k,b,w), everything works fine. It looks like I need to force the symbolic result to be evaluated at some point, similar to eval() for numeric calculations, but I don't understand how to do that. equ3.sm (34kb) downloaded 34 time(s).
Hi. Try this. equ3.sm (33kb) downloaded 42 time(s).Best regards. Alvaro.
Alvaro, Your version works. Do you have an idea how to generate sub-indexes from Range ? I need to generalize it for different n. Best regards, Igor Edited by user 10 April 2019 18:18:05(UTC)
Originally Posted by: tomtit The problem happens with taking derivatives. Smath can't calculate them without involving maple plugin. maple not needed to take derivative, directly from Smath native. TOM.sm (18kb) downloaded 25 time(s).
Originally Posted by: tomtit Do you have an idea how to generate sub-indexes from Range ? I need to generalize it for different n.
Hi Igor. Use this equ3.sm (33kb) downloaded 34 time(s).Best regards. Alvaro
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,493 Was thanked: 1274 time(s) in 745 post(s)
I think that here is the same problem that I mentioned earlier. maple() function doesn't know how to work with external definitions. Arguments must be explicitly defined. This limits the possibilities for its use. This is due to uncertainty - it is not clear what function is implied in the expression: maple diff() or smath diff(). Same for int() and others. I don't know how to solve this. |
Originally Posted by: uni I think that here is the same problem that I mentioned earlier. maple() function doesn't know how to work with external definitions. Arguments must be explicitly defined. This limits the possibilities for its use. This is due to uncertainty - it is not clear what function is implied in the expression: maple diff() or smath diff(). Same for int() and others. I don't know how to solve this. Hi. This is a workaround: use maple's 'value' function, which convert inert versions of some procedures to the actual procedures for evaluation. Usually, inert version have the same name, but with the first letter in uppercase. Notice that for Diff you must to disable Maxima plugin. Best regards. Alvaro.
on 10/04/2019(UTC), on 11/04/2019(UTC)
... ? any suite/comment
I'd like to clarify the problem. There were two issues in my worksheet. 1. Symbolic differentiation works strange: if you evaluate dA/dx symbolically and A is not a function of x it returns 0. That is correct. But if A is an indexed variable it returns dA[k]/dX = dA[k]/dx, that's wrong, A[k] is not a function of x. That was the reason to change indexes to subscripts. 2. I found workaround using maple(simplify(dA[k]/dx))=0. I can get right result in this case, but I can't use it in futher calculations. This is the main issue. If I'd be able to use the symbolic result as it was generated by maple plugin everything would be fine. Instead, Smath postpones symbolic evaluation and eventually reports "empty" or something like that when the expression gets too complicated. Edited by user 11 April 2019 16:33:01(UTC)
Originally Posted by: tomtit I'd like to clarify the problem. There were two issues in my worksheet. The first issue is the undefined upper limit in the summation. I made it Floor [in conformity to Mathcad] The 2nd issue is that maple has nothing to do in there. Native Smath expands symbolic, that you just assign. Once in there, you have two options: 1. Infinitesimal derivative 2. d/dx Smath operator fully compatible with expand(μ,b,ω) What is the problem ? Naturally, the vector of 'b' does not come from the sky You must create from source, or otherwise create from some kind of creator. I just put anything for demo but it can be anything else as well for you to try. Interesting brain storm ... Jean 0Appendix [BirdNest].sm (17kb) downloaded 24 time(s).
Jean, Regarding issue #1 I attached sym_diff_issue.sm (4kb) downloaded 20 time(s).. Where do you see "undefined upper limit" ? For issue #2 I attached equ3+remarks.sm (34kb) downloaded 22 time(s). with remarks. Regards, Igor
Originally Posted by: tomtit Where do you see "undefined upper limit" ? From some expansion of your original with odd 'n' [n=3] Smath reported the error just to confirm wrt Mathcad that 'Floor' by default Will check the other issue tonight. Jean
Originally Posted by: tomtit Where do you see "undefined upper limit" ? For the other issues equ3_remarks, your programs are incorrect. Set n=3 to see something equ3_remarks.sm (67kb) downloaded 17 time(s).
Igor, Your working algorithm is exemplified part 2 of the attached. Try it starting n>= 3. From there, past the derivative, what else should it be doing ? Cheers ... Jean 0Appendix [BidirectionalPulse].sm (23kb) downloaded 22 time(s).
Thanks Jean, Don't waste your time, I already have solved the problem. The n supposed to be odd number in the range 3,5,7,9,11. The practical case was 9. The goal was to derive system of 22 equations. They looked too complicated for doing it manually. I posted simplest case n=3 just to illustrate the issues I've encountered. Sorry, I can't go into details, that is a kinda commercial project . Edited by user 12 April 2019 15:23:03(UTC)
